Anyone see the benefits of owning a 200' fiberglass fishtape? I figure steel would be more beneficial since you won't be able to push a long fiberglass tape that far. I had someone asking me about picking one up.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Elecricity and steel tapes do not get along .
Working in a live panel fiberglass fishtape is the better idea . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
It depends on the type of fiber fish tape you're using. Some are designed to go hundreds of feet (I think that they might come in 500' lengths). Even better than steel in some instances.
The fiberglass ones are promoted as being non-conductive, easier to push and pull especially through bends since they are round, they also don't rust which is nice if your conduit is underground. You can get big diameter ones upto 1000 feet. The steel ones are tried and true and allot of guys like being able to cut the ends of and bending them the way they like. There make stainless ones also but are expensive.
I liked the metal because you can hook(form) them when pulling through walls to bend around objects.
yep.... I know about the benefits of using the steel tape and how the fiberglass is non-conductive. I just can't figure out how a 200' length glass one is able to sell. It gets extremely difficult to push after about 100'. No matter what size of the conduit.
Bob's right you can use lube. They say the fiberglass is easier to pull but I've never used one. If your going long runs many times your going to use a mouse.
How about a vacuum to pull a string through or air to push the Thread through then pull in a rope ,
Did this 40 years ago . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Tell us more about your prison experience Bob..
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I know all the alternatives to using a fishtape...just looking for the reason for a 200' glass tape. Easy Pull/Lube won't help with pushing a tape. It's more for putting on the head of a wire pull.
