Old 2/9/07, 2:45 PM
Rafael Rafael is offline
Please Note: Rafael is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default flickering lite
My bathroom light seems to dim when say like a blowdryer is being used in the bedroom next to it . Also seems to flicker alittle should i get this checked out by a sparky? i did check the plugs in the walls and they are drawing the 120v , can anyone help?
Old 2/9/07, 3:11 PM
Roy D. Cooke, Sr's Avatar
Default Re: flickering lite
Yes Please do it as soon as possible .
There can be many different things that could cause this and it does need immediate attention .
Roy Cooke........ Retired electrician
Old 2/9/07, 3:48 PM
staylor5's Avatar
staylor5 staylor5 is offline
It is most likely on the same circuit as the blower dryer. Any heating element draws a lot of power, which is why the light dims. The flicker may happen if it is a flouresent light. Try changing the ballast to a better ballast or just chage the whole fixture rated for damp locations.
Old 2/9/07, 4:09 PM
Also could be on the same circuit as Steven stated....but with the increased LOAD on the circuit it could be a loose netural condition as well....kinda gotta be their to do some tests.....right now we can only speculate i think.
Paul W. Abernathy
Old 2/9/07, 6:22 PM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Dimming lights...power problem.
Flickering lights...needs attention.
Lights Flickering while appliances start-up and while running. Jeff Nunz Electrical Inspections 15 11/27/07 4:04 PM
Convert your Mag Lite to LED rwand1 Inspection Hardware, Software & Publications 14 8/24/06 4:08 PM
