The cover on a floor outlet receptacle - does it have to be flush with floor? Or just 'should be' to not be trip hazard?
Couldn't find in IRC. Thanks, |
The ones I have seen are always flush with the floor.
It is raised about 1/4", plastic.
It does not "have" to be flush. You are correct, the only issue is a trip hazard.
Typically in a home they are under furniture. MANY I have seen and installed were not flush. |
Plastic would not be an approved floor outlet. Most are brass with metal covers when the outlet is not in use.
http://www.passandseymour.com/pdf/P14.pdf |
Floor receptacles without approved covers are a fire issue.
Picture the four year old with a cup of juice and it falls out of his/her hand and onto the floor and the juice seeps right into the receptacle. Sparks everywhere. I recommend (to my clients) that all horizontal floor receptacles be terminated and capped. When I do find these, there's only one or two in the house. |
1) Where was it stated that we were talking about boxes without approved covers???
Did I miss something? 2) I did not know juice could make "sparks". Sorry, this will NOT happen. 3) What is a "horizontal" floor box????? |
FYI....Just got this last week...
1. Lamson & Sessions Recalls Floor Electrical Outlets Due to Shock or Electrocution Hazards |
I stand corrected about plastic. But I have never seen one (until now online).
Plastic suddenly becomes more desireable when the customer sees how much the brass ones cost.
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've seen the cleaning lady short out a floor outlet while mopping. |
So it does not "have to be flush". Also while some covers are "flat" and fit flush into the floor, others are beveled and "rise" a little above the floor but the edges fit "into" the floor covering. If this is the case this would be a non-issue. Just curious, where is it located, Hallway, Bedroom, etc. are there other electrical outlets within 6 feet? Is the floor hardwood, vinyl, ceramic tile or carpeted? If the unfinished edges of the receptacle are slightly raised above the floor then there MIGHT BE the potential to "stub a toe or cut your feet." If that is the case then I would report it as a "potential" safety hazard. But from your post I do not believe that any of the unfinished edges are exposed so once again this would be a non-issue. Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 Last edited by fcarrio; 4/23/07 at 5:08 AM.. |
| Microwave receptacle | jwardenski | Electrical Inspections | 17 | 9/9/07 7:18 PM |
| What's This Receptacle For? | cmettel | Electrical Inspections | 7 | 5/25/07 7:35 AM |
| Bedroom receptacle | dnasser | Electrical Inspections | 9 | 4/16/07 10:33 AM |
| Online Code Check- Reference | pabernathy | Electrical Inspections | 31 | 11/9/06 3:39 PM |
| Wiring a Receptacle | jallingham | Electrical Inspections | 9 | 8/6/06 4:34 PM |
