Old 8/13/07, 10:34 AM
nbhi's Avatar
nbhi nbhi is offline
Default FP panel
Yesterdays inspection had a FP. Several breakers where turned off. one feeding the heat pump. When I tried resetting it tripped and sparked. I told the buyer that it was a safety issue and that I was not going to try again. He was ok with that, he heard the pop also. Just wondering what others would do in this situation.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 8/13/07, 10:45 AM
mnahrgang's Avatar
Default Re: FP panel
I would defer it to the HVAC professionals to deal with, along with a caveat that an electrician may need to get involved as well.
Mark Nahrgang
www.HeyMark.info
Old 8/13/07, 10:50 AM
Dale Duffy's Avatar
Hi Gary,
For starters I would not turn on a circuit breaker that was off when I arrived at the property, this is the responsibility of the homeowner (or whoever owns the home) to have the building ready for inspection.
When I receive a call for an inspection I make it very clear Everything must be on or tell me why something isn't if they know a problem exists. I also explain if something is not on, it will require me to return to the property and re-inspect any items that were off for Unknown Reasons if they want to turn anything on after I leave.
Besides circuit breakers, I don't turn any valves on, or plug something in that is unplugged as other examples.
I could just see myself now turning on a 240V breaker to a HVAC unit, the breaker stays on and I smell something burning while waiting for the the equipment to start.....oh oh......
Old 8/13/07, 10:52 AM
Mathew Hawley Mathew Hawley is offline
Gary,
I would have done the same thing and recommended the owner get an electrician to evaluate the system.
Here's what I use for FPE panels, feel free to use it:
The house has a Federal Pacific brand electric panel. This panel and the circuit breakers are considered by many experts to pose a latent fire hazard. At the present time there is no specific re-call for the equipment, nor is there a government warning regarding the hazard. Additional anecdotal data is available on the world wide web by searching "Federal Pacific Electric Panels".
Old 8/13/07, 11:08 AM
nbhi's Avatar
Good point Dale. We don't turn valves on either, but I thought I could very easily turn the breaker on. No more of that in the future.
Old 8/13/07, 11:37 AM
I had a similar issue were the realtor got all huffy and said show me which breaker I will do it myself. Well there was a missing knock out oppisite the breaker and she stuck her finger in to get some leverage to turn the breaker on. My heart skipped a beat, thought I was going to have to call a bambalance. Some people just don't get it.
Then there was the realtor that turn the water vavle at the water heater on after I told him not to... the stem and packing nut broke off in his hand, water everwhere, I went out front and turn the main off very slowly, I have seen theses brake as well.
Happy Inspecting
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 8/13/07, 2:18 PM
Frank Newman Frank Newman is offline
Please Note: Frank Newman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by dduffy
Hi Gary,
Absolutely - I believe this very item is covered in the SOPs. This is especially true if the breaker is found in the tripped position. I would just write it up as needing qualified investigation.....
Old 8/13/07, 4:42 PM
Charles Hellickson Charles Hellickson is offline
Here is what I use
You have a Federal Pacific panel which is legal, but there is a possibility that the circuit breakers may not trip when shorted possibly causing an electrical hazard. Opinions by licensed electricians on this panel varies between safe and unsafe. I recommend you consult a licensed electrician for an opinion and correct if necessary
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
