House was built in 1985. Federal Pacific Stab-lok main panel, no signs of overheating and warmest breaker was 70 degrees (same as the home interior).
I could not read these tiny labels. Are upgraded breakers available for these panels? If so, might these be examples? Just noticed too, that looks like a 12 g. wire in a 30 amp breaker. Last edited by kshepard; 10/2/08 at 2:40 AM.. |
Do not know if they are any different then what you have in the USA but they do not seem to be a concern here or a problem. It is the same company who makes SQ. D. http://www.schneider-electric.ca/www...-lok/index.htm Roy Cooke sr ... Royshomeinspection.com |
There are breakers manufactured as "replacement" breakers for FPE Stab-lok load centers - they are specifically listed as replacement breakers and cannot be used (according to the listing) for new installations.
In any event, there are more issues with Stab-lok load centers than just the breakers. The design is inherently flawed and the contacts are easily damaged during installation. If the FPE panels in Canada are the same Stab-lok design, they would be subject to the same potential issues although the breakers may be better than the originals (with regard to their failure rate). IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Canadian FPE Stab-Lok panels
FPE Stab-Lok panels in general Appears there are still problems regardless of where and when they are manufactured... Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
Joey D'Adamo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Aside from a recall of some 1996 FPE breakers, the FPE stuff isn't exactly generating much press up here. My favorite breaker panel design of all time is the Sylvania/GTE panels. The breakers actually screw into the busbar. No concern of them ever falling out when taking the cover off, and as long as the screws are tight, the connection is good. Those were very popular here in homes built in the late 70s-early 80s. These were also branded up here as "Commander" and a few others. |
smcarthur is a non-member guest and is in no way affiliated with InterNACHI or its members.
I looked at the link provided by Roy, and I can see that there have been some changes, at least to the "stabs" on the breakers. These used to be split so that there was a "spring" effect when snapping them in. It appears that these contacts are solid now, which would be a better design. The split contacts were easily damaged during installation which was one of the big problems with their design. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Federal Panel: test the circuit breakers? | fbartlo | Electrical Inspections | 8 | 4/30/07 2:18 PM |
| Panel Inspection Safety | roconnor | Electrical Inspections | 10 | 9/24/06 10:02 PM |
| Bryant Panel and Gould Breakers | tneumann | Electrical Inspections | 27 | 4/28/06 9:04 AM |
