Old 6/3/06, 5:38 PM
rarmstrong1 rarmstrong1 is offline
Default FPE Fuse Panel
I came across a Federal Pacific Panel in a house built in 1962. The panel was 150 Amps with two main fuse blocks and several fuses. Are FPE fuse panels a concern as well as FPE breaker panels? If so, what should we look for other than the obvious?
Old 6/3/06, 5:45 PM
Jeffrey R. Pope's Avatar
Default Re: FPE Fuse Panel
FPE fuses are no more problematic than any other brand. Stab-lok brand load centers are the only FPE product that has a "higher than normal" failure rate.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/3/06, 6:22 PM
Thanks, That's what I thought.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Fuse panel Michael Martin Electrical Inspections 7 11/1/07 3:18 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 10:02 PM
Fuse Panel Questions pdoane Electrical Inspections 8 9/21/06 9:37 AM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
