Old 1/14/06, 2:44 PM
John W. Springstead's Avatar
John W. Springstead John W. Springstead is offline
Default FPE panel question
Sorry to bother you guys, I researched the old posts of FPE Stab Lok, but couldn't fine an answer. What I noticed most was the lack of any main breaker. Also, the sub-panel is fed with #8 copper wire, again with lack of any type of controll.
How best to word recommendations? Thanks!
John Springstead
Home Inspections of USA
1752 N.E. Torch Lake Dr.
Central Lake, MI 49622
1-231-544-8016 office
1-231-544-6001 fax
www.homeinspectionsusa.us
Old 1/14/06, 5:19 PM
Jeffrey R. Pope's Avatar
Default Re: FPE panel question
That does not appear to be the service equipment which would account for the absence of a "main" disconnect. If it is the service equipment, a service disconnect is needed.
Info on FPE can be found here http://www.inspect-ny.com/fpe/fpepanel.htm
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/14/06, 11:48 PM
Thanks for the reply Jeff, I figured I could count on you!
Unfortunatly, this is the main service panel ( the top one ). If you notice the 3 main wires coming in on the top right side of the top panel, I traced those back to the meter base and overhead service from outside. As I mentioned, I just don't understand why there shoudn't be some type of main disconnect. The house was built in 1966, but surely they had "mains" back then?
Same with the sub-panel. Why not put in a 60 amp. 220v breaker to feed it?
Thanks again!
John Springstead
1-231-544-6001 fax
Old 1/15/06, 5:19 AM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
As much as I like FPE panels I think the obvious solution is about 1/4 stick of t.n.t., should take care of the problem. Maybe thats overkill but I just love FPE panels.
Larry
Subpanel wired as main panel. jlybolt Electrical Inspections 15 5/23/07 4:10 PM
Service Panel question for board sparkies pbolliger Electrical Inspections 8 5/14/06 9:24 AM
