Old 9/26/09, 2:53 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
Default Frayed Service Wires
Writing report on house I did last night. What you see is the main service wire traveling along a back outside wall from point A - Service Mast to point B - Service Meter. Would you write this up as needing replaced or would you state to monitor?
Bill Boerner
STL Home Inspection Services LLC
Serving St. Louis/Surrounding
(314) 805-2137
office@stlhomeinspector.com
http://www.stlhomeinspector.com
Residential, Commercial, Radon, Termite, Lateral Sewer Scopes
Find an InterNACHI certified Oklahoma Home Inspector (and anywhere else in North America)
Old 9/26/09, 3:08 PM
Dale Duffy's Avatar
Default Re: Frayed Service Wires
Good Lord--Not only is it installed improperly, it's SHOT---Replace it and install it correctly, by a electrician naturally---
Old 9/26/09, 3:54 PM
Dale how should the service wire be installed?
Bill Boerner
(314) 805-2137
Old 9/26/09, 4:13 PM
Dale Duffy's Avatar
Have the Buyer or Owner if they are making the upgrade ask the Electrician, your not an electrician, nor am I, and I don't know what the pictures are representing, need the full story. Large picture of the whole gig.
Sent Verizon Wireless Blackberry
Old 9/26/09, 4:44 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Short answer: In conduit....
Pictures on this inspection weren't necessarily of the conduit, but I think you get the idea.
frayed-service-wires-gedc0053.jpg   frayed-service-wires-gedc0054.jpg   frayed-service-wires-gedc0047.jpg
Old 9/26/09, 4:51 PM
Jim Port Jim Port is offline
Unmoderated Guest
Agree it is time to replace.
All I see is some straps missing. I don't see where conduit would be called for, at least as far the the pictures show.
Old 9/26/09, 7:26 PM
SE Cable is perfectly allowed for exterior applications...However, this SE Cable is "SHOT" and should be replaced as it presents a hazard. The Grounded conductor is exposed and it does carry current as well the ungrounded conductors I would bet are close to being exposed in some portions as you can see the insulation is nearly done as well. I can guarantee you the "insulation" properties on that ungrounded conductor is about "SHOT" as well.......since they will certainly have to replace it....you are doing them a GREAT service by informing them now.....!!!
Paul W. Abernathy
Old 9/26/09, 8:12 PM
Pics of the panel... Thanks everyone. Let me know if you see anything else. No manufacture data and no indication on the main breaker. My educated guess was corrected by a good friend to 100-125AMP MAX split buss panel. Manufacture is Cutler Hammer.
frayed-service-wires-jperez-048.jpg   frayed-service-wires-jperez-049.jpg   frayed-service-wires-jperez-050.jpg   frayed-service-wires-jperez-051.jpg   frayed-service-wires-jperez-052.jpg
Bill Boerner
(314) 805-2137
Old 9/26/09, 8:23 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Seriously??? You can't make that call? I can't believe you actually thought about writing it up as just something to "monitor". WTF!? Hell, while your at it just tell them to wrap it with some duct tape, while standing in a puddle of water.
Just my opinion.
Old 9/26/09, 8:24 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
10 (?) gauge wire connected to the main bus looks like a problem to me.
Old 9/26/09, 11:03 PM
Patrick Bolliger's Avatar
Triple tap at feeds, Open knock out at base of panel. Upper right corner of the panel buss... I see 30 Amp but can't make out what that is all about. Wire sizing maybe wrong there..
Old 9/26/09, 11:19 PM
Joe Funderburk, CMI's Avatar
Opening in the bottom of pic 1. Looks like a double tapped breaker in pic 3. Exposed romex should be in conduit in pic. 1. Where are the grounds?
Shouldn't the cables feeding the lower bus be protected from the sharp edges of the cabinet?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/27/09, 12:15 AM
Just my opinion.
Brian nice to see you wondered where you went. Yes I have a bad habit of second guessing myself. First time I've ever ran across a SE cable in such a condition as this one. Just wanted a sec opinion from the pros.
Bill Boerner
(314) 805-2137
Old 9/27/09, 12:19 AM
-- Panel is only grounded to earth. The entire home has no GFCI or three prong outlets.
-- Where do you see exposed Romex? Guess I'm missing it.
-- Not sure i see the sharp edges your talking about either.
Bill Boerner
(314) 805-2137
Old 9/27/09, 12:24 AM
-- Triple tap at feeds --- agreed
-- Open knock out at base --- agreed
-- 30 AMP I saw no problems. I can't remember exactly however it was for the furnace if I recall right could be wrong.
Bill Boerner
(314) 805-2137
Difficult Chimneys thance Inspecting HVAC Systems 2 1/29/08 8:16 PM
Two ground wires jlybolt Electrical Inspections 8 8/10/06 2:06 PM
Service Panel question for board sparkies pbolliger Electrical Inspections 8 5/14/06 9:24 AM
Service entrance conductor jjackson Electrical Inspections 30 1/7/06 5:05 AM
