| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
I touched the freon line of the AC unit and got zapped.... ouch.
John McKenna, CMI
Executive Director - Master Inspector Certification Board Inspector - Instructor - Thermographer (TREC #4565) 25 Yrs Constr Exp - 11 Yrs Home Inspector Exp American Home Inspection - East Texas. |
Stop doing that !!!
I was originally taught to check for 'ground faults' with my bare hands. Use the back of the hand.
tom |
apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Was it a static discharge or AC current? The other day a client turned on a switch and jumped, saying she got shocked. It was just static discharge as she brushed her finger over the cover screw. I did check to make sure it was not live.
Anatol |
John, how do you get to post large pictures?
the system has a 100k limit I thought.... To get shocked on a freon line, the ground has to be open at both equipment ends and a short from line to ground. Very uncommon problem it would seem. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 |
Highlight and copy (not copy image) Paste. Thats it. Yup, this is the first time I ever got shocked by a freon line. John McKenna, CMI
John McKenna, CMI
And let's not forget the possibility that it could be neutral current resulting from a compromised service neutral, which could easily place a potential on the grounding system. |
Bruce,
Thanks to Chris and his upgrades the photo limit has been increased to 250k and 800x800 res Happy Holdays Bruce Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
John,
Nice wake-up call, huh? You learn from your mistakes. Hey, what good does a pad do when it's at ground level? |
What John did was place his image on-line (his website) ---- as he stated, he simply cut and pasted this image. Due to the image being on-line already, it'll post directly on this MB as a large image. |
I agree with the idea of checking the neutral or grounding electrode for this. It could be a bad EGC to the HVAC system too.
Was the outer enclosure hot too? I know when I moved into this house the ground electrode was shot and I got the snot knocked out of me the first time I touched the stove while barefooted on the Terazzo floor. Last edited by Greg Fretwell; 12/25/07 at 1:27 PM.. |
John McKenna, CMI
Sounds like an open ground. Shocking story, glad you did not get hurt. BTW that type of electrocution is the most dangerous,very low voltage stops the heart, which is why GFCI's are designed to prevent this. I've seen this caused by Fire Ants also.
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical | 0 | 12/2/07 2:43 PM |
| 1 condensate line...... | Scott Schultz | HVAC | 2 | 11/4/07 7:18 AM |
| Size of supply line | aobrien | HVAC | 7 | 1/2/07 1:40 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing | 3 | 4/29/06 8:59 AM |
| Grounding the gas line | dmacy | Electrical | 18 | 3/14/06 11:47 AM |
