Old 4/26/06, 8:18 PM
kweiss's Avatar
kweiss kweiss is offline
Default Frequent burnt out bulb
Need some advice on a problem I ran into today and have heard about occasionally from customers.
The complaint is that they are going through light bulbs at an abnormal rate. While this is of course a subjective thing, what they describe does seem way too frequent to me. For instance, 4 - "4 year" halogen flood bulbs in one socket in one year. Today it was a one year old house on a warranty inspection. They had many burnt out bulbs, too many and too many different types to be just a bad batch.
Anyone have any suggestions on causes and resolutions to advise client about this?
Thanks
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 4/26/06, 8:25 PM
Default Re: Frequent burnt out bulb
Check for loose grounded conductor(s).
Old 4/26/06, 8:40 PM
Voltage issues in general.
Old 4/26/06, 8:43 PM
Is the house near a highway or RR tracks?..maybe vibration.
Just a thought.
Old 4/26/06, 8:49 PM
Kevin,
As larry stated I would suggest they have an electrician check the connections in the panel for the grounded conductors as well as check to ensure the light bulbs being placed in these lights MEET the requirements of the lights itself....could simply be a voltage problem
As for the halogen bulbs...make sure they know that when replacing those they do their best to not touch the bulbs to get oils on them....but I will say I see ALOT of halogens burn out simply because the spring settings and contact points are bad in the fixture itself...so if this is the SAME fixture in one year.....I would consider possibly replacement....the only thing they are out is the cost of a new light...NO Worries...they are cheap.
Sometimes loose connections within in the light itself can cause this as well.....but the largest thing I see that blows bulbs is slamming doors and so on lets say the wall a light is on....shakes the fixture...rattles the bulb and the filiment blows......Same for exterior lights...wind blows...shakes the fixture and filiment rattles and blows....
Another suggestion would be if they are lights that do not need a fancy bulb in and they simply want light...try some of the low wattage flourescent lights...the piggly wiggly looking ones....
Paul W. Abernathy
Old 4/26/06, 9:13 PM
bkelly1's Avatar
bkelly1 bkelly1 is offline
Please Note: bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Or 130 volt light bulbs.
Old 4/26/06, 9:20 PM
bkelly1's Avatar
http://www.factsfacts.com/MyHomeRepair/liteBulb.htm
Old 4/27/06, 12:45 AM
tmantsch's Avatar
tmantsch tmantsch is offline
Please Note: tmantsch is a non-member guest and is in no way affiliated with InterNACHI or its members.
If it's in the kids room. They need to take all objects kids think would
be fun to swing at the light fixture, out of the room. Start charging the kids $1.00 a bulb.
This may not work right away...but my money jar was full of $1's within a year.
I would replace the fixture...especially if it was stamped (MADE IN CHINA)
Light Bulb Clearance pdickerson Electrical Inspections 10 8/30/07 7:44 PM
Light Bulbs- All Ya Wanna Know pabernathy Electrical Inspections 9 4/18/07 7:22 PM
Light Bulb Savings Calculator swaskewicz General Inspection Discussion 0 11/11/06 10:11 AM
How many forum members to change a light bulb? kshepard Miscellaneous Discussion for Inspectors 9 8/2/06 9:56 AM
burnt wire Rafael Electrical Inspections 11 5/30/06 1:27 PM
