Old 9/21/10, 7:04 PM
Bert B. de Haan Bert B. de Haan is offline
Default Funky test result
I was using one of those $15 three light circuit testers on a receptacle. the tester lit up indicating correct wiring. As I went to pull it out, my thumb pushed on the GFCI test button. With the test button pushed in the lights lit up as if the Hot and Neutral were reversed. I had the same thing at another inspection once. Anyone have any idea what would make this happen?
Thanks.
Benchmark Home Inspection Services.
http://www.KitchenerWaterlooHomeInspector.ca Kitchener-Wateroo and Guelph area Home Inspection
Serving Kitchener-Waterloo, Guelph, Orangeville, Mount Forest and surrounding areas.
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/21/10, 7:40 PM
Jeffrey R. Pope's Avatar
Default Re: Funky test result
It means you pushed the test button. It is not indicative of any problem.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/21/10, 7:48 PM
I guess that is good but why does it only happen on that outlet? I couldn't get it to happen at any other outlets.
Old 9/21/10, 8:03 PM
Try it again, it will.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Please post questions about anything having to do with roofing kshepard Exterior Inspections 165 6/17/09 11:47 AM
Printing Test Result Certificates (posted by Philip D. Fenn) AskNACHI.org AskNACHI.org Inspection Questions Forum 1 5/12/08 6:55 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
