Michael Martin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Anyone see any isues with this 1960's GE split bus panel? I plan to put the house up for sale in the near future. The neutral/grounding busses, which cannot be seen very well, have only one conductor (both grounded and grounding) per hole. The two black wires at the top are connected to the subfeed lugs of the panel (which are protected by the main (upper) pullout) and run to a central A/C fused disconnect which is on the outside of the house almost right behind the panel. The upper pullout has 60A fuses; the lower (range) has 40A. The feeders are 2 AWG AL. All conductors on the circuits served by the two 20 A fuses are 12 AWG CU. The panel is rated at 125A, but the service appears to be 100A due to the feeder wire size. Thanks.
I feel it would be to your advantage to upgrade to a new Breaker panel, SQ D would be my choice .
This also will make people buying the home happy as they will feel this home has been maintaned . This is a huge concern to many people and some might not even consider looking further at the home. In todays market it pays to get every one to look at the home. My Thoughts ........ Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
One question I have is why are all the wires coming into the panel through the loom newer type wire and where are the connections of these newer wires to the old knob and tube wiring made up? Like Cookie said---upgrade the service.
Cookie hit the nail on the head
Randy |
I think it would be an irrational "happiness" on the part of the buyer. A shiny new breaker panel is not any safer than a properly installed and maintained type S fuse box. If there were no other upgrades to the system it would just be window dressing in my opinion.
Now, I will say that 99% of the time if I see a box like that, I will find other electrical issues and call for an electrician to eval and repair as needed. That is just my experience, yours may vary. Oh, and most of the time if you get an electrician looking over the system he will find many more issues that need addressing as he will want to rewire the entire place, etc. Good Luck! |
| Panel Inspection Safety | roconnor | Electrical Inspections | 10 | 9/24/06 10:02 PM |
| Fuse Panel Questions | pdoane | Electrical Inspections | 8 | 9/21/06 9:37 AM |
| FPE Fuse Panel | rarmstrong1 | Electrical Inspections | 2 | 6/3/06 6:22 PM |
