Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 10/10/07, 11:19 AM
Josh Rabanus Josh Rabanus is offline
Default Fusebox Bad?
I did an inspection a few days ago, and this place had a 100 amp fusebox. It had 30 amp fuse on 20 amp rated wiring. The reason for this according to the homeowner is because of the window air conditioner would blow the fuse. I know that the start up winding draws more amps at first but enough to blow a fuse? Does this sound right?
Thanks
Josh
Old 10/10/07, 12:04 PM
Bruce A. King's Avatar
Default Re: Fusebox Bad?
A slow blow type fuse at 20amps should work.
Do they make HACR type fuses?
Over sized breakers are ok on compressor circuits so maybe this is allowed?
Wait on the electricians to respond I guess.
www.BAKingHomeInspections.com
704 301-3207
Old 10/10/07, 12:08 PM
David P. Valley's Avatar
In my book, this 30 amp fuse is not allowed. I call out all 30 amp fuses on #12 AWG.
Old 10/10/07, 12:39 PM
Window shakers are designed to work on the circuit that matches the line plug. David is right a general lighting circuit needs to have the right fuse for the wire. It is only dedicated hard wired circuits that get to use the 440 rules that allow bigger O/C devices than 240.4(D) allow.
The installer has no control over what a user will plug in.
My guess is the window shaker is bad.
Old 10/10/07, 2:17 PM
Give it a time out...
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 10/10/07, 4:46 PM
mbarnett mbarnett is offline
When in doubt...refer it out.
Michael Barnett C.H.I. #NACHI07081803, HIF#9725A
Barnett's Certified Home Inspections BL#10009708
(661) 816-4123
www.barnetts-inspections.com
mbarnett@ca.nachi.org
www.nachi.org
Old 10/10/07, 5:28 PM
Paul W. Abernathy's Avatar
Send a message via AIM to pabernathy Send a message via MSN to pabernathy
Greg is 100% correct here, if the AC unit is designed for a 20A circuit then it should have no problems working on the 20A circuit. My guess is that circuit is not dedicated and when the AC starts along with something ELSE probably sharing the circuit it blows the fuse....
As for someone asking are fuses HACR rated...no......that would be delayed fuses but in this case......simply does not matter...putting in 30A on a 20A circuit just to keep it from tripping is wrong...the fuse was doing it's job.
Paul W. Abernathy,CMI,CEI,CEPE
NECŪ Consultant/Columnist
www.twitter.com/ElectricalGuru
- ICC & IAEI Certified Electrical Inspector
- ICC & IAEI Certified Electrical Plans Examiner
- Look for my article in the Nov/Dec 2009 IAEI Magazine
- 2007 "Top Gun" Winner - Mike Holt Enterprises
" visit www.TheElectricalGuru.com Today !"
Old 10/10/07, 6:00 PM
Marc D. Shunk's Avatar
I know you guys don't like codes and such, but here's an interesting tidbit just the same. The International Property Maintenance Code (which would make for interesting reading for any home inspector) actually requires that a fuse panel that shows evidence of overfusing be condemned.
Old 10/10/07, 6:04 PM
Kevin M. Kenny's Avatar
Kevin M. Kenny Kevin M. Kenny is offline
Got agree with Paul about this. If you found a 20 Amp breaker on 15 AWG wire because the microwave and the toaster keep blowing the circuit, you would call it out. Same diagnosis.
"Normal household circuit" are standard and any deviations from the standard are wrong.
Kevin
Kevin M. Kenny, Sr.
Kenny Home Inspections
Oak Forest, Illinois 60452
Nachi #6070990
http://kennyhomeinspections.com
Old 10/10/07, 9:35 PM
All i know is I love that word....."condemned"....always have.......I wanna be a slum lord when I grow up.
Old 10/10/07, 10:19 PM
I guess that's why you make the big bucks. You are probably right on that.
"The A/C goes out and the microwave screws up my popcorn"
Old 10/10/07, 11:20 PM
When I go on service calls for a breaker that trips a lot or a fuse that blows a lot (suspected overload), I've come to think that all homeowners are liars. I ask them first thing what else goes off when the breaker kicks or the fuse blows. The answer is often "nothing". When I turn out the fuse or turn off the offending breaker, it seems like half the house goes out. "Nothing" my a55.
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
