My voltage tester would go off within 12 inches of the fuses.
Is this ok? Wall switches, and electrical outlets I would have to make contact with my tester before the tester went off. ( I did this to see if my tester was too sensitive. ) David
An Ounce of prevention is better than a pound of cure :} |
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
If you're using a proximity style tester 12" may indicate that the metal enclosure is energized.
Great question , I agree the box could be hot .
Your post I am sure has helped many New and old Inspectors to please be carefull. Thanks and do not be shy on asking your questions ,all questions are good questions . Thanks ... Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Good morning gentlemen it has been a while but this is one I just can’t resist.
Looking at that panel I would be willing to bet that the neutral is bonded to the enclosure. If this is the case then as has been pointed out the cutout enclosure is at the same potential as the fuses which would make the non-contact meter start squealing like a pig at feed time. Mike Whitt Contractor/Instructor |
YEP! I agree with you Joseph. Seen that same situation on many sub panels.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Green fuses usually indicate 30 amp also...
So, did you open it?
| Inspector Wendy's Home Inspections-Service Areas | wforsyth | Miscellaneous Discussion for Inspectors | 57 | 9/5/06 11:10 PM |
| Buyers Best Home Inspections | ddinwoodie | Miscellaneous Discussion for Inspectors | 6 | 9/4/06 7:20 PM |
