Old 9/17/08, 9:03 PM
Bruce A. King's Avatar
Default garage circuit
New house, built under 2005 NEC, it has two attached garages that share the same circuit for receptacles.
The garages do not share any common walls with each other so would this be considered two garages where each should have its own circuit?
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 9/17/08, 9:24 PM
Jeffrey R. Pope's Avatar
Default Re: garage circuit
I am not aware that a garage requires its own circuit. . . Is that an '05 requirement?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/17/08, 9:44 PM
Unmoderated Guest
EACH attached garage requires a receptacle. There is no wording that requires a circuit for each.
Old 9/17/08, 9:59 PM
Sorry, I wrote that all wrong, the garage circuit also has the exterior receptacles on it.
Looks like another minimum installation allowed by code.
704 301-3207
Old 9/17/08, 10:05 PM
Barry Adair's Avatar
Very common around here for "all exterior receptacles" to be controlled by the garage GFCI receptacle.
Did I miss something?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/17/08, 10:06 PM
rshuey rshuey is offline
Please Note: rshuey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Minimum, yes, but it would be pretty hard to overload that circuit. Unless, you are using power strips everywhere or decorate for Christmas like Tim Allen, you would be alright.
Old 9/17/08, 10:58 PM
Terry Clayton Terry Clayton is offline
I don't have a code book handy but I recall the Receptacle for the Garage has to be GFCI protected being an unfinished floor as would all exterior and garage receptacle ( I believe the exception would be the automatic opener 8' above grade). Unfortunately there are some who but the GFCI in the garage or outside that controls the bathrooms. Hope it helps
Old 9/17/08, 11:05 PM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you are on 2005 NEC code or earlier verison that will be fine but later one like 2008 unforteally no it no longer have the exception there so everything in the garage have to be GFCI'ed both receptale and lighting circuit and of course GDO { Garage door opener }
Merci,Marc
Old 9/17/08, 11:11 PM
If they use a single receptacle for the opener is it still required to GFCI protected
Old 9/17/08, 11:16 PM
Unmoderated Guest
Under 2005 it could even be a duplex and still not be GFI in the ceiling.
Under 2008 EVERY 125v-15 & 20 amp receptacle in a garage must be GFI protected. All exceptions for garages were removed.
Old 9/17/08, 11:19 PM
Thanks guess it time to buy the book again
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Smokes on AFI circuits lprinzi Electrical Inspections 9 7/6/06 9:12 PM
