Old 11/22/07, 12:27 AM
cfolsom cfolsom is offline
Default Garage door opener extension cord
Hi,
I'm looking for a reference to back up my opinion that the garage door opener should have its own outlet and not be served by a long extension cord.
Thanks in advance,
Corey
Old 11/22/07, 5:17 AM
Brian E. Kelly's Avatar
Default Re: Garage door opener extension cord
http://www.geniecompany.com/docs/GENIE%20CHAINGLIDE-ENG.pdf
Extension cords are for temporary power only.
DO NOT USE AN EXTENSION CORD!
Extension cords can cause dangerous
overheating conditions.
DO NOT USE A PORTABLE GENERATOR!
This product is designed to operate on
standard house current. Do not use
alternate power supplies.
WARNING
5
You need a 110-120 Volt power supply
available
. The outlet should be no more than 3
feet from the power head once it is mounted. (The
cord is 4 ft. in length.) SEE WARNING BELOW
Old 11/22/07, 6:32 AM
msylvester's Avatar
msylvester msylvester is offline
Send a message via AIM to msylvester
No referance but this is the narative I use.
Extension cords are being used as permanent wiring in one or more areas. They should only be used for portable equipment on a temporary basis. Using extension cords as permanent wiring poses a fire and shock hazard, and is an indication that wiring is not adequate and should be updated. Recommend either removing extension cords or having a qualified electrician evaluate and make modifications as necessary. For example, install additional circuits and/or electric outlets.
Mark Sylvester
P.I. Home Inspection Services
www.pihomeinspection.com
mark@pihomeinspection.com
Old 11/22/07, 7:46 AM
David P. Valley's Avatar
All garage door openers should be plugged directly into an outlet located adjacent to the opener. No extension cords.
Old 11/22/07, 12:49 PM
Jeffrey R. Pope's Avatar
http://www.nachi.org/forum/f19/extension-cords-permanent-application-22469/
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Extension Cord Wiring psmothers Electrical Inspections 1 6/4/06 9:11 PM
Joe F, update? jtedesco1 Electrical Inspections 54 4/10/06 10:35 AM
