How much sheetrock is required on walls adjacent to garage panels?
New house, has 3 feet+ on right side, top and bottom but only 1 inch at left side. Code reference? thanks! added with edit: question does not pertain to working space, simply sheetrock on exterior garage walls around panels. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 Last edited by bking; 9/15/07 at 12:11 AM.. |
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
There is no electrical requirement to have any wall covering in place.
Attachment 14522 Last edited by dvalley; 10/7/07 at 4:40 PM.. |
But my understanding is that 30" requirement is not a fixed dimension. In other words, it can be 30" from the left edge of the panel and extending out to the right. I don't think there's anything wrong with 1" clearance on the left.
The question is not about working space...
Simply sheetrock around garage panels for fireblocking or cable protection issues. Must be a code reason somewhere because even the cheapest builders will put some drywall around the garage panel, even when on an exterior wall. Here is a discussion about this... but still no code reason to have it.... http://boards.hgtv.com/eve/forums/a/...2/m/7351097013 B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 Last edited by bking; 9/15/07 at 12:05 AM.. |
OK then, are you saying that the rest of the garage is not rocked? Why would putting up a little sheetrock around an electrical panel provide any fireblocking? I guess I can't quite see the scenario so I'll bow out gracefully now before I confuse myself any further.
Only the garage walls adjacent to the living space are covered.
Around here they put a sheet up around the panel. Maybe just for a better fit for the panel cover? Just thought of a good reason, this helps prevent access to the panel knockouts and discourages homeowner wiring. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Is there a local requirement for this? It certainly isn't required in my area.
It has to be for protection of the romexes leaving the panel.
A panel mounted to the studs with no sheetrock around it would have exposed home runs. Around here it would fail a final inspection, the conductors at that height would be considered subject to damage. Also, I am certain the IRC, which is used by our local building inspectors, prohibits exposed Romex less than 7 feet from the floor. |
Feel free to call out exposed romex if it gives you warm fuzzies to do so, but it meets the letter of the NEC and the IRC. I'm sure someone's bound to point out that you're held to a different standard as home inspectors, existance of local rules, blah, blah, blah... |
Then it must be a local thing, I know we are never allowed exposed Romex where it is low enough to be possibly damaged. I guess our inspectors are mis interpereting 300.4
I'd sure like to know where the 7 foot rule came from, it is used by all of our county & city inspectors. I do not see it in our NEC ammendments. P.S. I am not the guy who calls it out, I am the guy who gets called out to fix it! |
I believe there is a code about not having exposed wiring within 6 or 7 feet of attic stairs or scuttles.
| One panel in the garage | pmagrone | Electrical Inspections | 30 | 8/2/07 5:32 PM |
| sheetrock dust in distribution panel | jweinberg | Electrical Inspections | 5 | 10/12/06 11:43 AM |
