Old 8/4/08, 1:50 PM
sbenson sbenson is offline
Default Garbage Disposal GFCI ??
Should a garbage disposal receptacle be GFCI protected. It is a switched receptacle but it is also within 6 feet of the sink (though underneath). I have always worked on the assumption that it should be even though it is switched.
Sam
Old 8/4/08, 2:28 PM
Mike Whitt's Avatar
Unmoderated Guest
Default Re: Garbage Disposal GFCI ??
If the disposal is on a wet bar or laundry sink then it would require GFCI protection.
If the disposal is for the kitchen sink then it would not require GFCI protection.
Old 8/4/08, 7:50 PM
Mike are you assuming cord and plug connected? (as the OP specified)
If so he is pointing out that 210.8(A)(6) <kitchen in a dwelling> only requires GFCI on the receptacles serving the countertop but (7) <laundry, utility and wet bar sinks> does not make the countertop distinction and just says where the receptacles are installed within 6 feet.
A hard wired disposal in a wet bar sink would not require GFCI
Old 8/4/08, 10:16 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
99 and 02 codes state: Wet Bar Sinks. Where the receptacles are installed to serve the countertop surfaces and are located within 6 ft. of the outside edge of the wet bar sink. I don't have the other code books on hand.
www.mauihomeinspections.com
Old 8/4/08, 10:53 PM
Mike Whitt's Avatar
Unmoderated Guest
2008 cycle
(7) Laundry, utility, and wet bar sinks — where the receptacles are installed within 1.8 m (6 ft) of the outside edge of the sink
You do make a point though of if it was in compliance when it was installed it is still in compliance today
Old 8/5/08, 12:14 AM
Unmoderated Guest
I do and I will recommend upgrades to the current standards noting that the upgrades are not required. I also include a little blurb about the importance of GFCI protected outlets.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 12:29 PM
Garbage Disposal Trap? bkelly2 Plumbing Inspections 1 1/17/07 2:54 AM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 9:31 AM
