I would like an opinion on a few of these pictures. GarbageDisposal1 had the Romex properly clamped at the disposal, but there was no junction box visible (just a hole in the drywall). ..2, 3, and 4 serviced a dishwasher and the disposal. Obviously, the romex was not properly clamped, the j-box was loose. There were staples...Hummm I think that's not quite right.
Just would like to hear back how others may report these situations. Thanks in advance for your help! Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
| Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America) |
Improperly wired
I recommend a Licensed Electrician examine and evaluate . |
How about if the qualified professional just repairs it. You have already evaluated it as improper, n'est pas? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Since you like detail , lets hear yours |
Electrical feeder for garbage disposal is not properly secured. This could lead to problems including electrical shorts if something would snag the cable. Recommend repairs by a licensed electrician or other qualified individual.
I prefer.. Conductors are a fire hazard as routed and need to be reinstalled by a licensed and certified Electrician .
(damn I hate that Romex stuff) |
Improper and amateurish wiring noted (see photos) for dishwasher and disposal under kitchen sink. Recommend repairs by qualified professional as needed for safety.
The cable exiting the wall is not an issue.
There should have been a cable clamp screwed into the bottom of the disposal. Non-metallic cable is not for use with cord caps. |
EXACTLY!!
Word it however you feel fit, but finish it with "should be repaired by a qualified electrician." IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
that guy Harry sure does get around
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
This is actually a great thread in that those are some common things we see DIYers do. Jim is 100% correct in that those NM Cables are not Flexible Cord and that alone warrants a call out. The connection to the Disposal is incorrect as you all know and will be called out at the same time.
The way the NM Cable is run in itself is subject to physical damage as they could have routed it in a way that would be less subject in nature so that also is called out. Report : Observations of serious electrical defects under your kitchen sink will warrant an evaluation by a licensed electrical contractor. Nonmetallic cable is being installed in areas subject to physical damage, used in an improper manner as a flexible cord to the disposal and without properly being secured to the disposal itself. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
| Garbage disposal | acox | General Inspection Discussion | 37 | 1/10/09 11:02 AM |
| Garbage Disposal GFCI ?? | sbenson | Electrical Inspections | 5 | 8/5/08 1:14 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
| Garbage Disposal Trap? | bkelly2 | Plumbing Inspections | 1 | 1/17/07 3:54 AM |
