I did a New home inspection this am and noted the Gas Range was plugged into a GFCI protected outlet. Is this a new requirement? I was thinking 1. all appliances were supposed to be on their own dedicated circuit(this shares the circuit with at least 2 other receptacles) and 2. They should not be on a GFCI protected circuit. Thoughts?
Greg Allen,Certified Home Inspector NACHI ID# 05082583 1st Choice Inspection Services, LLC Apex, NC 27502 "Greater Raleigh-Durham Home Inspections and Radon Mitigation Services" http://homeinspectorguy.com "Paying attention to simple little things that most men neglect makes a few men rich" Henry Ford |
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
We had a thread on this here and over at I-news, code allows it (an exemption) as long as the manufacturer does not prohibit it.
http://www.inspectionnews.net/home_i...-ignitors.html B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Thanks Bruce. That makes sense. I think I will also double check with the Building Inspector too.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| HELP! What do you call a GFCI outlet technically? | gromicko | Electrical Inspections | 7 | 1/8/09 7:01 PM |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| Bathroom outlet near floor: GFCI | mthomas2 | Electrical Inspections | 3 | 4/13/07 11:35 PM |
