sziedman is a non-member guest and is in no way affiliated with InterNACHI or its members.
GE 100 amp Main panel, year about 1955.
It has 2 50amp main breakers, not tied together. Is this a safety issue? I think it could be. I would send photo, but I cannot see how to do it. |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Click "go advanced" below at quick reply and click on the paper clip to add a picture.
What if someone forgets about the 100Amp and just hits one toggle.
He will be fried on the other end. Don't need a code for that one. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Based on your info a photo or photo's is/are needed to accurately answer your question.
galaxyhomeinspections.com An amateur built the Ark ! Professionals built the Titanic ! |
So the assumption is that these are 50 amp, single pole, 120 volt circuit breakers?
You've been a licensed home inspector since 2002. I recommend you take some CE classes . Concentrate on electrical subjects. Or just pay the fee and become a CMI. BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
| Main Panel vs Sub-Panel and main disconnect? | rbassett | Electrical Inspections | 11 | 10/24/09 6:16 PM |
| Why does this type of panel have two main breakers? | areid | Electrical Inspections | 22 | 4/23/08 12:42 AM |
| 6 breaker exceeded | mhazelwood | Electrical Inspections | 48 | 3/14/08 1:57 AM |
