Old 2/16/08, 9:30 PM
nbhi's Avatar
nbhi nbhi is offline
Default GE Panel
Todays panel has four breakers, combined, single pull, rated at 200amps. the panel is rated at 400amp. This is a 200amp service?
Thanks
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 2/16/08, 9:37 PM
Unmoderated Guest
Default Re: GE Panel
I think a pic is going to be required, unless someone is familiar with this particular panel.
Actually, if it is anything like some Siemens panels, they use a similar setup for 200 amps. They use two 2-pole 100A main breakers in parallel, giving 200 amps. It looks like four single pole breakers tied together. There was a thread not too long ago about this.
This is probably the same thing but for 400A.
Old 2/17/08, 9:09 AM
nbhi's Avatar
Speedy
I think this is the same set up you are talking about. There are 4, it looks single pole 200amps breakers, with one pole switch controlling them all.
Attachment 18699
Thanks
Old 2/17/08, 9:21 AM
nbhi's Avatar
The SEC is 4/0 AWG also. It is rated for 200amps correct?
Old 2/17/08, 9:28 AM
Unmoderated Guest
Yup, that's exactly what I was referring to.
200 amps for sure.
Old 2/17/08, 9:29 AM
Bruce A. King's Avatar
Looks like a standard 200A GE panel, the main breaker is 200A, the extra 200A labels are misleading.
Where did you see 400A?
No way that is a 400A panel.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 2/17/08, 9:34 AM
nbhi's Avatar
Bruce
The wording in the panel. No wait, it was hand written on the label. Probably the electrician did it. So, this isn't a 400amp rated panel?
Old 2/17/08, 10:21 AM
Unmoderated Guest
Oh yeah. I forgot you mentioned 400 amps.
NO WAY is this a 400A panel.
Old 2/17/08, 4:50 PM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by nbhi
Speedy
Attachment 18699
Thanks
I am famiur with this panel and it is only 200 amp main breaker as what Speedy Pete he got it right on first answer.
BTW if this is a 400 amp the breaker box and the size of main breaker is much larger than what the photo showed.
Merci, Marc
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
