Old 9/30/10, 4:09 PM
Mark S. Tyson Mark S. Tyson is offline
Default Generator Back Up
Why would you want to hire a licensed electrician to install one of those expensive generator switches and panel when you can do it yourself for pennies on the dollar. Just back feed the panel thru the meter socket
generator-back-up-florence-lockwood-002.jpg   generator-back-up-florence-lockwood-015.jpg
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/30/10, 4:13 PM
Brian E. Kelly's Avatar
Default Re: Generator Back Up
Old 9/30/10, 4:33 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Love it!.....Florida ROCKS...sad thing is that it probably WAS installed my an electrical contractor!
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 9/30/10, 5:48 PM
Joe Funderburk, CMI's Avatar
Never seen this before. What's photo 1 showing? Hard to see. No obvious problem to me.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/30/10, 5:58 PM
Bruce A. King's Avatar
Thats an RV outlet. 120V 30 amp No problem assuming it is wired right.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 9/30/10, 6:05 PM
David A. Andersen's Avatar
Except you may kill someone working on the damaged line that you just plugged your power into!
Breakers only break the hot legs...
Oh yea, neutrals don't carry nothing does they?!
What am I thinking...
BPI# 5015804
Old 9/30/10, 6:09 PM
Where's the generator come into play? I don't see one. The panel itself was designed that way. Please educate me to the problem.
Theodore Roosevelt
Joe Funderburk, CMI
Old 9/30/10, 6:42 PM
Those 30 amp 120V outlets even fool licensed electricians, many have wired them to 240V and smoked customers RV's.
The only problem is if they double tapped into the meter box, but of course it may have additional lugs installed in there for the other service panel.
The cable is not properly attached to the house.
The cable is probably not rated for service use either.
Did the power company put an anti-tamper tag on the meter box?
I was just answering the original post that incorrectly referred to it as a generator hookup.
Of course someone can rig up a cable and backfeed that 120V RV outlet but that is the case with any outlet.
704 301-3207
Old 10/1/10, 1:17 PM
Robert Meier's Avatar
Is this truly for a generator hookup (only 120 volts)? If this is connected to the load side of the meter there are likely some violations as it's installed.
1-The enclosure would need to be service rated.
2-There would need to be a connection to the grounding electrode system.
3-The meter enclosure would require suitable lugs for more than one conductor.
There are some issues as mentioned by others in this thread.
