Old 7/22/10, 3:18 PM
Frank Magdefrau's Avatar
Frank Magdefrau Frank Magdefrau is offline
Default Generator suggestion
What size/type generator would you recommend that will start up and run a home that is equipped up to a 5 ton air conditioning system for a period long enough to perform a full home inspection?
Frank Magdefrau
Certified Master Inspector
DeSoto Home Inspection Services, LLC
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
InterNACHI Member since 2002
InterNACHI message board member since 2003
InterNACHI ESOP member from 2004 to 2010
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/22/10, 3:38 PM
Default Re: Generator suggestion
Somewhere around 18kw to 20kw for the 5 ton AC plus whatever else the home requirements are.
http://www.allworlddieselgen.com/faq.htm
Larry Kage, CMI
231 929 3525
Old 7/22/10, 4:12 PM
Jim Port Jim Port is offline
Unmoderated Guest
How do you plan to make the connections between the genset and the house panel?
Old 7/22/10, 5:50 PM
Back feed through the dryer plug.
Frank Magdefrau
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
Old 7/22/10, 5:53 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Another idea: Hook right into the panel through a breaker, Bring your own if you have to. Be sure the main disconnect is off.
Old 7/22/10, 5:58 PM
Allot of the homes have fuse panels.
Frank Magdefrau
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
Old 7/22/10, 6:06 PM
Joe Funderburk, CMI's Avatar
Sounds sort of risky to me. What if the power is off at the house for a valid reason and you come along and energize it. Better put 911 on speed dial!
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 7/22/10, 6:54 PM
John Onofrey's Avatar
John Onofrey John Onofrey is offline
This is an idea that could very likely end very badly so let's give Frank all the help we can. JK, lol
Frank are you seriously gonna lug a 20 kva generator around and try to back feed it into service panels? If so, pass me some of what you are smoking because I'm having trouble visualizing this.
John Onofrey Licensed Professional Inspector
Houston Home Inspection
Houston Home Inspector
www.texasinspectors.net
John Onofrey
President, Grail Media, LLC
"Effortless Email Marketing"
www.homehintsenews.com
2007 INACHI Inventions and Innovations Award Winner
Free! Inspector Email Marketing trial click here
Old 7/22/10, 7:00 PM
Banned
If the house AC and all other needs for the inspection happen to hit teh suggested 18 kW, that will be a draw of 75 amps @ 240 volts.......hopefully the 30 amp dryer breaker works as some dryer wire may get fried.
My advice: don't do it!!
Hire an electrician to do this so he will have the liability when something goes wrong!!! Have the electrician remove the meter from the meter box also......can't be too safe......the linemen will respect you!!
Old 7/22/10, 8:37 PM
Robert Meier's Avatar
Back feeding a dryer plug is a horrible idea not to mention illegal. Forget to turn off the main and your 120/240 volt generator is sending 7200 volts back over the primary line that someone may be working on to restore the power. A transfer switch or some sort of breaker interlock is what you should use. When using an automatic transfer switch (ATS) the generator is required to be large enough to carry the entire connected load. A manual transfer switch allows the user to select loads as he chooses.
As others have advised I would suggest consulting a licensed electrician before you open yourself up to a huge amount of liability.
Old 7/22/10, 8:44 PM
Banned
I didn't mention that as everyone on this thread should know that.......but it appeared that it was going to happen anyways......so I tried to protect the linemen.....remove the meter socket as a disconnect!!
Old 7/22/10, 8:47 PM
Yes your idea will offer protection to the linemen but IMO cutting the seal or lock off of the meter enclosure is also a poor idea when you should be installing the system correctly to begin with. Also plugging the meter back live when the utility power is restored isn't such a great idea either.
Old 7/22/10, 8:49 PM
Stephen W. Stanczyk's Avatar
I thought Forest Gump was from Alabama. I guess dumb ideas transcend state borders.
Stupid is as stupid does.
Stephen Stanczyk
Old 7/22/10, 8:58 PM
Unmoderated Guest
I understood that this was only for while the inspection was in progress but, there is no way to run that kind of load thru the dryer plug even if it were legal to do. Find another way to do this or disclaim it.
Old 7/22/10, 10:03 PM
Banned
Yes your idea will offer protection to the linemen but IMO cutting the seal or lock off of the meter enclosure is also a poor idea when (1) you should be installing the system correctly to begin with. Also (2) plugging the meter back live when the utility power is restored isn't such a great idea either.
(1) How much will it cost to install a generator transfer switch for a 3-4 hour inspection?
(2) if the house disconnect is in the "off" position, no current will be drawn. I've seen a meter replaced by the utility with the triplex still intact at the masthead. I did not see them disconnect the triplex at the transformer.
