Anyone ever have a GFCI circuit register normal, then when tripped with a testing device, register reverse polarity?
I had it happen to me today. All of the GFCI's (exterior, garage, bathrooms) were tied to a single GFCI in the Hall Bath, which is normal. When I intentially tripped the exterior GFCI, it went directly to registering reversed. All of the GFCI's on that circuit registered reversed (garage and master bath). When I get up to the Hall Bath, I reset the tripped GFCI, then test it again. It registered "all green." But, once I tripped it, it went back to reversed. Never had a GFCI do that. Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared Thermographer®, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
I'm not sure about the whole rev pol thing, but what I wonder about is having all those outlets tied together, seems a bit crowded to me (that's definitely not "normal" in my parts).
Hope all is well over your way. |
Defective GFCI receptacle.
Your three-light tester "reads" it as reverse polarity, but it's actually just a bad reset. In this condition, if you had plugged in a SureTest, or some other device that needs a bit more current, the circuit would have tripped again. http://www.nachi.org/forum/f19/do-you-write-up-open-neutral-31340/ IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Definitely wrote it up as defective, but wanted to see if anyone else came across this scenario. Thanks again for the info....your always here to help Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared Thermographer®, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
rshuey is a non-member guest and is in no way affiliated with InterNACHI or its members.
yes, it is happened to me, then I reset it and try again and it usually is ok...
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| More GFCI info from U/L | Greg Fretwell | Electrical Inspections | 9 | 12/4/07 8:33 PM |
| GFCI Safety Notice | rcooke | Electrical Inspections | 1 | 10/30/07 12:29 PM |
| The question asked on the new HI Study test here? | jtedesco1 | Electrical Inspections | 28 | 10/4/06 9:31 AM |
