Old 10/16/09, 2:29 PM
jrider jrider is offline
Please Note: jrider is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default GFCI
Tested a GFCI receptacle and the lights on my tester showed everything to be okay. Pushed the button on tester and the gfci did not trip and the tester lights changed to reverse polarity. Can anyone explain? Thanks.
Jason R.
Find an InterNACHI certified Mississippi Home Inspector (and anywhere else in North America)
Old 10/16/09, 3:58 PM
Christopher Currins's Avatar
Default Re: GFCI
You have a faulty GFCI.
Christopher Currins
Certified, Licensed
Old 10/16/09, 4:27 PM
Jeffrey R. Pope's Avatar
Default Re: GFCI
Defective GFCI receptacle. . .
This is common for GFCI receptacles manufactured prior to the "lock-out" type that are manufactured currently. I'm guessing the receptacle was manufactured in the '80's to early '90's.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/16/09, 7:45 PM
Default Re: GFCI
Jason R.
I find that in about half of the pre-2000 homes I inspect. Jeffy's correct--GFCI don't work so good.
Old 10/17/09, 3:37 AM
Default Re: GFCI
always double check your "Tester" in a different plug to verify it is working and if it is then regardless of what it could be, it is clear the receptacle has some sort of problem be is defective or reverse polarity....either way note it as abnormal and defer to licensed electrical contractor.
Paul W. Abernathy
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 12:29 PM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 9:31 AM
