Old 7/31/11, 11:49 AM
GLENN R. HELDER GLENN R. HELDER is offline
Default gfci
does a gfci need a ground to be effective?REPLACING A TWO PRONG OUTLET WITH A THREE PRONG GFCI
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/31/11, 12:00 PM
Robert Meier's Avatar
Default Re: gfci
Nope, it will operate just fine in a ungrounded system. Although it has the word ground in it's name it has nothing to do with the operation of the device itself. Also GFCI circuit breakers require a neutral connection to operate but not a ground.
Old 7/31/11, 12:03 PM
Default Re: gfci
A grounding-type receptacle without a ground is a safe installation as long as the GFCI protection circuitry within the device has not failed from shorts and voltage transients. To insure proper GFCI protection, test the GFCI monthly in accordance with the manufactures instructions and if the GFCI test does not operate properly, replace the GFCI protection device.
Read here for more information;
http://www.mikeholt.com/mojonewsarch...d~19991230.php
Old 7/31/11, 12:49 PM
Greg W. Mathias, CCHI Greg W. Mathias, CCHI is offline
Default Re: gfci
When I test GFCI with an outside source they never trip if there is no ground. Why is this? How do I know for sure they are not a safety hazard? Any help with this would be valuable to me and many others with the same issue. I use the ideal circuit tester with the short cord. Can't think of the item # right now.
Greg Mathias, CCHI
Journeyman Carpenter
Global Property Inspections
Lloydminster, AB. Canada
(780)205-9912
Old 7/31/11, 12:55 PM
Default Re: gfci
The reason that it won't trip is because of your testing method. If it's a GFCI receptacle just press the TEST button. Your tester requires an EGC to cause the 4-6ma current imbalance which the GFCI circuitry will read. No EGC, no imbalance, therefore incorrect test results. Although it now appears that the GFCI device doesn't work it may actually be working just fine.
Old 7/31/11, 12:59 PM
Default Re: gfci
Thank you Robert, is there a better method to test them? I have called them up before as defective and reported that they be replaced. If I just use the test button and they react properly I will mark them acceptable correct?
Greg Mathias, CCHI
(780)205-9912
Old 7/31/11, 3:11 PM
Christopher Currins's Avatar
Default Re: gfci
The Test button is the recommended way to properly test a GFCI.
Also if a GFCI is open ground it should be labeled "no equipment ground"
Christopher Currins
Certified, Licensed
Old 8/1/11, 12:57 AM
Robert J. OConnor's Avatar
Default Re: gfci
Do that with you night night (errrr 3-light tester) plugged in ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 8/1/11, 7:11 AM
David A. Andersen's Avatar
Default Re: gfci
Why must there always be a "better way" of doing things?
Is pushing the test button too sissified? Something that the homeowner could do just won't cut it?
"Man-Up"! Put a 10d finish nail in the plug and stick your ***** (what-ever) in the sink of water!
** Just kidding! Don't do this at home, leave it to the "experts"!
BPI# 5015804
Old 8/3/11, 3:34 PM
Lawrence W. Losciale's Avatar
Lawrence W. Losciale Lawrence W. Losciale is offline
Default Re: gfci
So what if you test the gfci outlet with the button on it, it works, but then you test the down stream outlets with the "night lite" but can't get them to trip?
Old 8/3/11, 5:04 PM
Default Re: gfci
Simplest explanation would be that the downstream receptacle is ungrounded.
Old 8/3/11, 5:08 PM
Default Re: gfci
Trip the gfci with the test button and then check the downstream ones to see if they are off.
Greg Mathias, CCHI
(780)205-9912
Old 8/3/11, 6:55 PM
Default Re: gfci
As posted; Stick your "body parts" in the plug and see what happens...
Push the button and see if the power turns off elsewhere.
What more do you want?
It don't work with an external tester without a D a m n Ground.
AS POSTED.
You need one of NACHI's letters advising that you need more damn training (like many of us got)...
Why are you asking us? We are not "NACHI Certified" these days.
If your not a moron CMI that has nothing to do but collect boyscout Merritt badges, you don't qualify here.
But till they kick me out, I can still say stupid s h i t and advise the world that Burkson is as worthless pile of dog crap.
BPI# 5015804
Old 8/3/11, 8:55 PM
Default Re: gfci
Originally Posted by dandersen View Post
As posted; ...Push the button and see if the power turns off elsewhere.
It don't work with an external tester without a D a m n Ground...
I'm ignoring the rest of that post as it adds nothing to the question.
I know it won't "work with an external tester without a D a m n Ground"
What I'm saying is that with "a D a m n Ground", if the down stream outlets don't trip the GFCI how do you KNOW they're protected.
Yes when the GFCI trips there's no power but will a ground fault in those down stream outlets cause it to trip?
Old 8/4/11, 4:56 AM
Default Re: gfci
Good question. You could use a solenoid style tester (AKA Wiggy) and test from the hot to a good known ground. The imbalance of the current from the tester will trip the upstream GFCI. I sometimes use an extension cord plugged into a grounded receptacle or test to a grounded water pipe. A high impedance testing device like a digital multi-meter (DMM) won't work in this test because the current imbalance imposed isn't great enough to trip the GFCI.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 12:29 PM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 9:31 AM
UL Information about Testing of GFCIs jtedesco1 Electrical Inspections 0 2/5/06 4:38 PM
