I inspected a home that has a GFCI breaker for the tub, but the motor wire that plugged into the outlet was 2 wire. Safety concern?? I don't thnk the GFCI will trip.
Thank you Tim |
| Find an InterNACHI certified Hawaii Home Inspector (and anywhere else in North America) |
The GFCI looks for the imbalance between hot and neutral, while a ground is highly recommended, if it is properly wired it will still trip. Was it bonded?
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com Last edited by bgraham; 8/25/09 at 6:15 AM.. |
I hope the GFI still works as I don't have any three prong kitchen and bath small applainces, although the pump on the tub should be grounded somehow.
www.MauiHomeInspections.com |
A 3 light tester uses the grounding conductor in the test. There is no grounding conductor on a 2 wire sysytem. If a GFCI is used on a 2 wire system, the test button on the device must be used. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| whirlpool tub motor | Scott Schultz | Electrical Inspections | 2 | 5/31/07 7:42 PM |
| Cleaning Whirlpool Baths or Bathroom Spas? | kkenny | General Inspection Discussion | 29 | 3/14/07 12:36 AM |
| Lights & GFCI Outlets | thejnicki | Electrical Inspections | 14 | 2/28/07 3:48 PM |
