Old 10/14/10, 12:12 AM
pnarron pnarron is offline
Default Gfci in bedroom?
When I was testing outlets in 2 bedrooms I hit the button to trip the gfci and it cut the power to the outlets in each bedroom. The house was built in 2002 and I checked the panel and found the 2 breakers in the attached photo. Are these GFCI breakers? Why would they have GFCI breakers for a bedroom?
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/14/10, 12:27 AM
Bob Elliott's Avatar
Default Re: Gfci in bedroom?
That should be an AFCI and is rated at 10,000 volts for amp interruption capacity.
Old 10/14/10, 4:12 AM
Why would it trip with a cheap GFCI tester? The house was strange. The front exterior outlet would trip, but still had power to it, the rear exterior outlet was on the same circuit and would not function unless the front outlet was reset.
Old 10/14/10, 10:28 AM
Jeffrey R. Pope's Avatar
The installer put in the wrong type of breaker.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/14/10, 10:53 AM
Jim Port Jim Port is offline
Unmoderated Guest
Jeff, could you clarify?
IIRC the Square D AFCIs have either a white or blue test button. Some were also green.
Old 10/14/10, 11:14 AM
Based on the fact that the breaker tripped using the GFCI function of the tester, I'm assuming the breakers are GFCI's rather than AFCI's.
I've seen GFCI's and AFCI's that are very similar in appearance, and I have seen where they have been mistakenly misplaced, so this is my guess.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/14/10, 11:28 AM
Unmoderated Guest
Thats what I thought you were saying.
Old 10/14/10, 11:47 AM
Phil do you have a picture of the inside panel?
I would not assume this is a GFCI breaker as they also have orange buttons on AFCI and it is possible to trip them with a 3 button tester which is why we do not test them that way.
http://www.inspectapedia.com/electri...ion_Safety.htm
Old 10/14/10, 12:31 PM
I do test AFCI breakers, even though it may not be "required."
Ground-faults and arc-faults are not the same, and I have never been able to trip an AFCI breaker by using the GFCI test button.
I have seen AFCI breakers in blue, green, yellow, white and orange, and I have seen GFCI breakers in white, yellow and red.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/14/10, 12:46 PM
Jeff I have tripped AFCI breakers with a 3 light tester long ago0 however the best way is to only use the button in the panel.
Others have reported the same over time here but that is why you should never use 3 light testers on AFCI.
Paul Abernathy has made comments on this subject in the past.
Just as I suspected. . .
http://www.idealtruevalue.com/servlet/the-7907/Detail
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/14/10, 1:29 PM
Unmoderated Guest
A plug-in tester should be set to trip a Class A GFI device. Class A is the 5mA protection level.
The GFI component of the AFCI is the Class B 30 mA.
Old 10/14/10, 2:00 PM
David C. Macy's Avatar
That is a good catch, when I first read the post the looked like AFCI breakers.
Nice find!!
Old 10/14/10, 2:19 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Good job Jeff.
www.MauiHomeInspections.com
Old 10/14/10, 2:27 PM
Christopher Currins's Avatar
I'd also question why it's only 15 amp serving a bedroom.
Christopher Currins
Certified, Licensed
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 12:29 PM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 9:31 AM
UL Information about Testing of GFCIs jtedesco1 Electrical Inspections 0 2/5/06 4:38 PM
