gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Electrical geniuses
I looked at a house that was renovated from the 50's. They updated to GFCI's, which is obviously a good thing. My question is, do you have to have GFCI protection on the same side that a refrigerator is if it has water going to it..i.e. an icemaker?? Just seems to me there should be a GFCI if the fridge has water going to it. What do you guys think? Thanks, |
I'm not an elctrical genuis, but I would think not.
An errantly tripped or otherwise defective GFCI could spoil a lot of food without anyone even noticing until too late. The probability of food poisoning could outweigh the likelihood of being electrocuted by a fridge. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
Refrigerators shouldn't be plugged into GFCI receptacles as they may trip them at start up.
(I'm far, far from an electrical genious, so we'll see how quickly I'm told how wrong I am) Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
There has been discussion here on this matter and the concensus has been that it may trip and ruin a lot of food and maybe even let the beer get warm.
Howdy,
If the Fridge in question is in the basement or lets say a garage in question.....and the plug is behind it.....you do not need to place it on GFCI.....is their anything wrong with it being on GFCI...nope...perfectly fine and has nothing to do with the "Water" running within it for an ice maker lets say. We install the circuits in kitchens all the time as well....hit the fridge as the first receptacle...and then go to the next one..the first one on the counter and place a GFCI their.....now everything beyond it is protected. So in short....nope the fridge does not need to be on GFCI......even in a location that would require GFCI..like a unfinished basement....if the fridge is in place...and without going into too much detail...then it would not need to be on GFCI.......but the others would. Hope this helps... Paul W. Abernathy |
lcapaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here the refrigerator is required to be on a dedicated circuit, but CodeCheck show that Ref's OK on individual circuit > 15 amps, it must be a local code modification I guess. |
Lewis,
it is fine for a fridge to be on a dedicated circuit of 15A....or 20A in that fact...or with the counter top for that additional fact. (B) Small Appliances. (1) Receptacle Outlets Served. In the kitchen, pantry, breakfast room, dining room, or similar area of a dwelling unit, the two or more 20-ampere small-appliance branch circuits required by 210.11(C)(1) shall serve all receptacle outlets covered by 210.52(A) and (C) and receptacle outlets for refrigeration equipment. Exception No. 1: In addition to the required receptacles speci fied by 210.52, switched receptacles supplied from a general-purpose branch circuit as defined in 210.70(A)(1), Exception No. 1, shall be permitted. Exception No. 2: The receptacle outlet for refrigeration equipment shall be permitted to be supplied from an individual branch circuit rated 15 amperes or greater. Paul W. Abernathy |
Lewis,
I am sure it can be in YOUR area also...IF you wish to fight a good fight...they would have to adopt it formally....and in written down somewhere otherwise AHJ's can't re-write code or impose their own WILL...they can just define it as it is supposed to be written or per their ......interpretations... and just possibly they MAY get it wrong...we are all human....AHJ's want to learn like anyone else.....educate them... So while it may be the WAY in your area......could just be from their ignorance......or just lack of understanding of the NEC... 90.4 Enforcement. This Code is intended to be suitable for mandatory application by governmental bodies that exercise legal jurisdiction over electrical installations, including signaling and communications systems, and for use by insurance inspectors. The authority having jurisdiction for enforcement of the Code has the responsibility for making interpretations of the rules, for deciding on the approval of equipment and materials, and for granting the special permission contemplated in a number of the rules. By special permission, the authority having jurisdiction may waive speci.c requirements in this Code or permit alternative methods where it is assured that equivalent objectives can be achieved by establishing and maintaining effective safety. This Code may require new products, constructions, or materials that may not yet be available at the time the Code is adopted. In such event, the authority having jurisdiction may permit the use of the products, constructions, or materials that comply with the most recent previous edition of this Code adopted by the jurisdiction. Paul W. Abernathy |
I know the answer is no, but he brought it up because of the water line. Water get it? Good point...
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
lol.....water has nothing to do with GFCI placement.....the NEC tells us where the GFCI's need/should be....
I think you have a better chance of slipping and falling down the stairs during an inspection than to be electrocuted from the water line to the fridge leaking..since it is usually connected at the bottom of the fridge... I was refering to the ignorance of the local AHJ if they demand something a certain way....even if the NEC allows something another way.......not the inspector who posted it......it was a great point and makes for a great learning experience. Paul W. Abernathy |
Inspected a home one day that the main electrical panel was behind the fridge.
One case that I did move the fridge to check the panel. 100-amp service with Split HVAC, stove, water heater, outside spa and a wall heater. Panel was moved and upgraded prior to closing. |
Paul
Is it a reportable safety issue if the fridge socket is a dual or single? rlb |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| Inspection Pointers Here | jtedesco1 | Electrical Inspections | 3 | 3/15/08 9:19 AM |
| GFCI Safety Notice | rcooke | Electrical Inspections | 1 | 10/30/07 12:29 PM |
| The question asked on the new HI Study test here? | jtedesco1 | Electrical Inspections | 28 | 10/4/06 9:31 AM |
| UL Information about Testing of GFCIs | jtedesco1 | Electrical Inspections | 0 | 2/5/06 4:38 PM |
