Old 8/30/10, 8:21 PM
Richard Hyland Richard Hyland is offline
Default GFCI breaker no common
Will a GFIC breaker still function as a standard breaker that is as a circuit protector, if the common conductor (white) is not connected to the neutral bus bar?
Thank you
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/30/10, 8:32 PM
Bruce A. King's Avatar
Default Re: GFCI breaker no common
I have a few of these and will try it out tomorrow on my shop panel.
edit: checked it out on the GE type GFCI breakers.
Both white wires on the breaker must be connected to the neutral bus to get any current flow since the neutral current passes through the breaker.
The GFCI feature will work/test ok with the branch neutral wire disconnected and the pigtail neutral connected but the load will not work.
So the answer is "no" it won't function as a breaker but it has no need to since a load will not work anyway.
www.BAKingHomeInspections.com
704 301-3207
Old 8/30/10, 9:17 PM
Randy McKay Randy McKay is offline
I had a GFCI today that tripped as soon as I plugged my tester in it today, same problem?
Randy McKay
InterNACHI member
CanNACHI - CMHI
Infrared Certified
IAC2 Certified
Mr. Home Inspection Services Inc
Calgary, Alberta
www.MrHomeInspections.ca
Old 8/30/10, 9:23 PM
Robert Meier's Avatar
Is the branch circuit neutral connected to the breaker?
Old 8/30/10, 9:29 PM
the branch circuit wasn't identified, I couldn't start to turn off breakers.
Randy McKay
InterNACHI member
CanNACHI - CMHI
Infrared Certified
IAC2 Certified
Calgary, Alberta
Old 8/30/10, 9:39 PM
Without the neutral pigtail on the CB connected the GFCI function should not work. It should still function as an overcurrent protection device. A 2 pole GFCI CB with no load neutral will still provide GFCI protection if the CB neutral pigtail is connected to the neutral bus.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 2 1/8/11 8:04 PM
Outlets protected by GFCI circuit breaker? Nathan W. Swilling Electrical Inspections 7 4/11/08 2:02 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 9:33 PM
Double tapped GFCI breaker sspradling Electrical Inspections 6 12/9/06 11:51 AM
