Old 10/21/10, 3:43 PM
lhood lhood is offline
Default GFCI Installation
I recently inspected an older home with a 2 wire system.In lieu of providing a new 3 wire system the contractor installed GFCI outlets through out the house. The bathroom and kitchen both have reset buttons,but would not trip at the outlet or at the panel breaker.I used a 3 prong tester without any success.How to I confirm that the system is working correctly,and can AFCI be provided on the same system in the bedrooms.Any advice would be appreciated.
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/21/10, 4:20 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: GFCI Installation
The 3 light tester will not trip a GFI installed on a two wire setup. The correct way to test is the TEST button on the device. If the power goes off it is working. The 3 light works by sending some current to the ground pin. Since the ground pin is floating it will not complete the circuit to trip the device.
The fix provided by installing the GFI receptacle or breaker is a code compliant method. The "No Equipment Ground" sticker should have been applied to the coverplates.
AFAIK the AFCI breaker can be installed without problems if the panel will accept the breaker.
Old 10/22/10, 9:02 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
You can also test this gfci with a voltage tester. Just put 1 lead in the jot side and the other in the ground, the gfci should trip is the plug is properly wired and grounded.
Old 10/22/10, 9:38 PM
Robert Meier's Avatar
I'm not sure how that would works since this receptacle is ungrounded. However as James pointed out you can use a voltage tester and go from the receptacle hot to a known grounded source like a water pipe and depending on the type of tester it will trip the GFCI.
Old 10/24/10, 10:53 AM
Tim Spargo's Avatar
I've tested this same setup with a *Wiggy* solenoid type tester, for the down stream outlets.
This is likely what you're talking about, just to clarify.
I generally don't see the required *GFCI Protected* AND *NO Equipement Ground* stickers provided on the outlets to let me know what I'm looking at.... I end up stumbling across a GFCI in a sleeping or living area and go from there.
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 10/24/10, 12:28 PM
According to the NEC, GFCI protected stickers are not required, but the no equipment ground are.
You're correct about the Wiggy solenoid style tester. They will generate enough of an imbalance to trip the GFCI protection provided you're testing to a solidly grounded object.. Many electronic testers or DMM's will not.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 12:29 PM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 9:31 AM
