Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 6/20/06, 1:45 AM
LiveAd LiveAd is offline
Please Note: LiveAd is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default GFCI Outlets w/ No Test Button - Dont Work! HELP PLEASE!
After resetting all the "breakers" on the side of my house I noticed an outlet that didnt come back on. I started testing other outlets and found that there were quite a few that did not work. Some of them were marked with a sticker that say "gfci protected outlet" but do not have the typical reset and test buttons. These are the ones that are not getting power since I flipped the breakers... YES i am sure the breakers are on "on".
My question is how do I make these otlets work again? What checklist should I go by? A couple that do not work now are ones that had something plugged in like a nightlight in a bathroom or one of my backyard outlets. NO they are not wet.
Any information would be helpful and appreciated!
Please email me at power@liveadvertiser.com or reply here or even better... do both!?!?
Thnx again!!!
David
Old 6/20/06, 2:00 AM
Default Re: GFCI Outlets w/ No Test Button - Dont Work! HELP PLEASE!
There is probably a GFCI outlet that you have not located that is tripped. Check all the bathrooms, outside on your patio, and in the garage again.
"Never ever threaten anyone in Camoflage"
Tim Wilson
"Not everyone follows the same path"
Governor Sanford, musings on the Appalachian Trail
Old 6/20/06, 2:07 AM
Is it possible that they wont reset because something is plugged into them when I hit the breakers?
Are you saying that there HAS to be an outlet that has a reset that is "above" the ones that do not work? Why would they stop working if i simply flipped the breakers?
Old 6/20/06, 2:19 AM
Somewhere there is one or more GFCI outlets that are tripped, you need to find them and re set them. The other outlets are on the tripped ciruit or circuits.
Tim Wilson
Old 6/20/06, 11:47 AM
Jeffrey R. Pope's Avatar
The sticker is informational only, it does not imply that the receptacle has a built-in GFCI.
Brian is correct. Somewhere there is a GFCI receptacle or GFCI circuit breaker which has not been reset.
Do you have a hydro-spa in any of your bathrooms? It may be located inside the access hatch (shouldn't be, but could be).
When was the house built? That may help us narrow it down.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Installing GFCI in garage with no ground cyezza Electrical 53 11/30/07 6:05 PM
GFCI Safety Notice rcooke Electrical 1 10/30/07 1:29 PM
GFCI Test Light gmacandog Electrical 4 5/17/07 5:39 PM
Ungrounded downstream GFCI scosta Electrical 17 3/9/07 9:00 AM
UL Information about Testing of GFCIs jtedesco1 Electrical 0 2/5/06 5:38 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
