I tested kitchen outlets the other day. One GFCI outlet with two protected outlets down stream. The first one I tested was the outlet in the middle. Everything was fine until I reset the GFCI, power did not return to the middle outlet but the last outlet did have power. No matter what I did I could not get any power back to this outlet. Can someone enlighten me as to what is going on?
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
No, I'm sure it was this GFCI. I heard the distinct pop of the GFCI when I used my tester on the outlet. I've added a photo showing where the outlets were. GFCI outlet to the right of the sink, outlet with no power to the left and a third outlet farther to the left.
There's another GFI somewhere. Especially since kitchens should have two circuits. I usually leapfrog the circuits with receptacles in the kitchen.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Jeff is most likely correct. If the kitchen counter top is wired correctly it should have 2 separate 20 amp circuits and the outlets should be staggered from 1 circuit to the other...
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
Well, I guess it's possible. I did not see another GFCI, but it could be hidden somewhere.
That is one way of doing it but it's not required to wired that way. Personally I would not stagger them but that's just me.
David... (right side of pic)... was that (tv or computer ?) plugged into a GFCI? Protected by same as above? Any GFCI's in panel?
There is no requirement for the circuit to be staggered. You could have one circuit on one side and the other on another wall. You could also have one receptacle on one circuit and all the other small appliance receptacles on the other circuit. The NEC only requires a minimum of 2 20 amp circuits. It does not specify the arrangement of those circuits.
Yes, it's permitted. Quote:
Thanks for posting that article Robert.
Thanks, I thought it was. Always good to be reassured.
Robert, I have been running into homes from the 80's with the rear patio receptacle covered by one of the kitchen GFCI. Any idea when this changed or is it still allowed?
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
| Gas range using a GFCI protected outlet | gallen1 | Electrical Inspections | 2 | 1/29/10 4:24 PM |
| Installing GFCI in garage with no ground | cyezza | Electrical Inspections | 53 | 11/30/07 5:05 PM |
| UL Information about Testing of GFCIs | jtedesco1 | Electrical Inspections | 0 | 2/5/06 4:38 PM |
