Old 10/6/09, 12:21 AM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Default GFCI Question
At todays inspection I had GFCI outlets on both sides of the kitchen sink. Each had it's own test/ reset buttons. Using my tester, I tested the one on the right and it worked fine. When I tested the one on the left, it tripped the one on the right. Seems like it would have tripped itself. Is this a common setup or is it a defect? When I think about it, it doesn't seem to be a problem. First time I ran into this one.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Find an InterNACHI certified Oklahoma Home Inspector (and anywhere else in North America)
Old 10/6/09, 12:31 AM
Joe Funderburk, CMI's Avatar
Default Re: GFCI Question
As long as one tripped somewhere I wouldn't be concerned.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 10/6/09, 12:41 AM
Thx Joe. It did its job
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 10/6/09, 12:43 AM
I've run into similar situations in the past. The trouble seems to be in resetting them.
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/6/09, 1:36 AM
Probably just a brain-fart when they installed it. They just slaved a GFI off another GFI. Could've saved $10.00 and installed a regular receptacle.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 10/6/09, 1:42 AM
Chuck Evans's Avatar
Jeff
Yep, second one is redundant. Either one could trip first when the downstream device is tested.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 10/6/09, 1:48 AM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
How old is the house? With modern homes there are supposed to be 2 small appliance circuits. If there are only 2 GFCI's and they are both on the same circuit, does that mean there is only 1 circuit or is the 2nd circuit not GFCI protected or is there a 3rd GFCI in the kitchen protecting the 2nd circuit?
Stephen Stanczyk
Old 10/6/09, 2:16 AM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
A tip I have learned the hard way:
If you trip a GFCI and it won't reset, there is a chance that you tripped a second, redundant GFCI upstream. If they both trip at the same time, the downstream one won't reset until the upstream one is reset.
That is one reason it is best to use the test button on the receptacle instead of the one on your tester.
Old 10/6/09, 12:26 PM
Jeffrey R. Pope's Avatar
Sorry to disagree.
Although most manufacturers say that this is how it should be done, I have run across many GFCI's that will "trip" with their test button, but will remain energized.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/6/09, 12:32 PM
rbrady's Avatar
Will these same GFCI's de-energize when tripped with the external tester? I always try my tester if it doesn't trip with the test button, but I can't recall one that worked with one and not the other.
My main point in using the test button on the receptacle was to avoid tripping a redundent GFCI, which you may not be aware of, then trying to chase it down. I have had that happen a few times.
Old 10/6/09, 12:43 PM
No, they don't de-energize even though the test button "trips." I understand the nuisance of redundant GFCI's, and I report them as a "nuisance."
I'm saying, make sure you've got a tester plugged into the receptacle to check for voltage - just because the internal tester trips, doesn't mean the GFCI is functional.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/6/09, 12:57 PM
rbrady's Avatar
I agree.
I always have my tester/indicator plugged in when I push the receptacle test button. It can make it difficult to get to the button.
Installing GFCI in garage with no ground cyezza Electrical Inspections 53 11/30/07 6:05 PM
Ungrounded GFCI srinner Electrical Inspections 29 11/30/07 11:15 AM
GFCI Question mdavis5 Electrical Inspections 4 9/12/07 9:22 PM
Chicago GFCI question mthomas2 Electrical Inspections 10 8/28/07 10:37 AM
GFCI Question jvogan Electrical Inspections 4 8/25/07 3:28 PM
