Old 6/11/10, 8:16 PM
Jeffrey R. Pope's Avatar
Default GFCI Required?
Here's one for you. This is just for discussion. I'm not looking for an "answer."
This receptacle is in a bedroom. Should it include GFCI protection? The NEC does not require it here.
There's more here than meets the eye.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/11/10, 8:22 PM
Ed Bancroft Ed Bancroft is offline
Default Re: GFCI Required?
OK I will take a guess.
Was it an add on and wired in to exterior circuit outlet on other side?
Old 6/11/10, 8:26 PM
Dale Duffy's Avatar
Hi Jeff
If what looks like brown staining at the window sill is moisture I'd say add a GFCI---
Or if that is a Pool in back (hard to see) and someone ran an extension cord out the window, may want a GFCI---
Or if that Chair is actually an Aquarium disguised as a Chair, I'd say add a GFCI--- --
Hope all is well....!
Old 6/11/10, 8:29 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
If it is, then is the exterior outlet a GFCI and is this interior outlet downstream? If yes to both then this outlet is protected.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 6/11/10, 8:38 PM
Brian C. Hoagland Brian C. Hoagland is offline
Is that a spa in the adjacent bathroom I can't see through the blinds? If so yes, if not, well you tell me.
Old 6/11/10, 8:43 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
I say Brian got it. Looks like a tile or stone deck under the blinds, so I am guessing this is a jacuzzi tub beyond the blinds.
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Old 6/11/10, 8:45 PM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
next photo please...what is behind the blinds..hummm
Old 6/11/10, 8:54 PM
Brian E. Kelly's Avatar
Brian has my guess also...
Yes It needs a GFCI outlet, a Main Disconnect, and some sort of Grippable Rail.
And after further review the entire area looks slippery too, recommend Velcro...
Old 6/11/10, 8:59 PM
Here's the rest of the photo. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/11/10, 9:09 PM
Good one Jeff, never would have guessed that was a jacuzzi behind door #3
Old 6/11/10, 9:35 PM
Good fun! More please
Darin Redding, CPI
Facebook Like
619-663-8740
Old 6/11/10, 11:05 PM
Robert Meier's Avatar
I this a hydromassage tub? If so GFCI protection is required for that receptacle. If not in a bathroom and not a hydromassage tub no GFCI protection is required. From the 2008 NEC:
680.71 Protection.
Hydromassage bathtubs and their associated electrical components shall be on an individual branch circuit(s) and protected by a readily accessible ground-fault circuit interrupter. All 125-volt, single-phase receptacles not exceeding 30 amperes and located within 1.83 m (6 ft) measured horizontally of the inside walls of a hydromassage tub shall be protected by a ground-fault circuit interrupter.
Old 6/11/10, 11:21 PM
Nope. Just a standard tub.
Jeff Pope
Santa Clarita CA
(661) 212-0738
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 10:06 AM
