The house was built in 1955, two wire system no ground.
They installed GFCI's in the bathrooms....the GFCI test open ground and do not trip. What is a good write up for this situation? David
An Ounce of prevention is better than a pound of cure :} |
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Did you use the integral test button on the receptacle to trip it?
Yep i was about to say test with the test button only your tester will not work on Non grounded outlet, Outlet is still protected with GFCI ( as long as you tried it and it worked)
The 3 button tester may not be effective but as mentioned you should use the GFCI test button.
Jim Kathy is a non-member guest and is in no way affiliated with InterNACHI or its members.
If properly tested, using the GFCI Test button, and did not trip, then write in your report that the GFCI receptacle did not respond to the Test button.
You should write up that the outlets are missing the required labels for "GFCI Protected" and "No Equipment Ground"
Your GFCI tester does not work on outlets that have no ground. Use the manufacturer supplied test button. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
A grounding connection is not required for proper function of GFCI protection. The only issue (assuming the internal test button opens the circuit) is that there is no label on the receptacle.
Yes....
Thanks everybody for the feedback.....
David,
Was anything done to the home, or it's electrical system, that would have triggered a requirement for an upgrade to the circuits? Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Rarely is there a case where existing circuits would have to be grounded as a condition of the permit application.
Same for the kitchen. I am now running into some AHJ's that are requiring some homes with K&T to upgrade the circuits (needing GFCI by todays standards) to upgrade those circuits when performing Panel upgrades (which we see a lot of around here). Long overdue as far as I'm concerned. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
Then, it needs repair/repacement.
| BC is acting on the new bill | jkoong | Canadian Inspectors | 21 | 2/19/08 7:38 AM |
| IR In The Market Place | jmckenna1 | Thermal Imaging, Infrared Cameras & Energy Audits | 4 | 12/18/07 6:43 PM |
| Misinformed CAHPI member? | rwand1 | Canadian Inspectors | 4 | 8/1/06 9:39 PM |
| GFCI in older home | kheintzelman | Electrical Inspections | 6 | 4/14/06 7:28 PM |
