Today I completed an inspection and when plugging the gfci tester into a 3 prong outlet all three lights were lit? The center light was the brightest, and the outer lights were glowing noticably. There is not code on the tester explaining what the hell this means, reverse polarity, open ground and open nuetral? Has anyone ever seen this? George
| Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America) |
Testers vary from model to model. If I came across this, I would have gotten out my testing meter, possibly something funky with the voltage?
I have seen this in Tucson also. Don't know the answer.
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
I found this once. Someone removed the 240v outlet for an a/c and installed a 120v rated outlet but still wired it 240v.
www.MauiHomeInspections.com |
Thats why it pays to carry a standard voltage tester and multi meter.
The only way to get all 3 lights to light is with voltage on the neutral.
Could be 120V from neutral to ground and 240V from neutral to hot. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
That's what I've found, too.
Whatever it is, it's not right.
Brings back memories of a recent inspection.
Open ground, Open ground, Reverse polarity, Reverse Polarity, False Ground, BBBBBBZZZZZZZTTTTTT. Dead Ideal Sure Tester. Glad they stand behind there warranties. |
was it on a dimmer? I have seen this before. I plug in a lamp if there is one available and see if the outlet behaves as expected. It does not take much to get that condition and the neutral is supposed to carry current back to the panel. If no dimmer, a poor neutral connection may exhibit unusual indications.
| Inspection Pointers Here | jtedesco1 | Electrical Inspections | 3 | 3/15/08 10:19 AM |
| Installing GFCI in garage with no ground | cyezza | Electrical Inspections | 53 | 11/30/07 6:05 PM |
| GFCI Safety Notice | rcooke | Electrical Inspections | 1 | 10/30/07 1:29 PM |
| GFCI Question | jvogan | Electrical Inspections | 4 | 8/25/07 3:28 PM |
| Adequate service size....oh, and a GFCI question | ksherstobetoff | Electrical Inspections | 13 | 2/8/07 2:18 PM |
