Since this outlet is within 6' of the sink should it be GFCI? It is not. It does not serve the kitchen counter or does it?
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I do not consider it to serve the countertop, therefore no gfci needed.
My rule of thumb, when in doubt, if I cannot touch the outlet while standing in front of the counter, (not the sink) than it does not serve the countertop. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Yep it should be GFCI
to me the common sense applies. If you plugged something in where would you set it? To me it looks as though you would set it on the counter directly above the sink...
If a standard cord will reach water it should be GFCI protected.
Richard Fitzwater FYI Property Inspection El Paso, TX TREC#8317 www.el-paso-home-inspector.com www.fyiproperty.homestead.com |
Must be within 18 inches of the surface to be considered as needing it according to code.
I put up a valiant fight for the other side in a forum fight a few years back, but you can call it out depending on the situation in my opinion. |
Scenario...
for the sake of discussion (since we don't know the actual info) let's say the sink is 3 feet from the hallway wall... let's say there is an outlet 2 ft 10 inches into the hallway, at counter level... does that outlet serve the counter??? No, and neither does this outlet. Not to say it couldn't be, but it is not intended to be. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
204 comments on the subject here: http://www.nachi.org/forum/f19/inter...43/index6.html
Most appliance cords are not long enough to reach that outlet.
Not serving the counter IMHO. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
GFCI
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
Quite nicely summed up Bob. Not required by Code.
If you read my old comments ,you already know not to get me started.
Absolutely NOT required.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| More GFCI info from U/L | Greg Fretwell | Electrical Inspections | 9 | 12/4/07 8:33 PM |
| GFCI Safety Notice | rcooke | Electrical Inspections | 1 | 10/30/07 12:29 PM |
| The question asked on the new HI Study test here? | jtedesco1 | Electrical Inspections | 28 | 10/4/06 9:31 AM |
