| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
I see this form time to time and wonder how others write this up.
I wrote this. Quote:
"Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
| Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America) |
The GFCI receptacle is defective or mis-wired and should be serviced by a qualified electrician.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Wow, short and sweet Jeff. Much better than my mangled narrative. "Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
One GFCI(Ground Fault Circuit Interupter) outlet works even when tripped, which is currently not a true GFCI outlet. This is a safety issue that needs to be corrected. A qualified licensed electrical contractor should correct as needed.
A little long winded, but having the word safety included gives the client an idea as to the seriousness of the needed repair. Loren Green Greens Home Design L.L.C. www.GreensHomeDesign.com www.MyPhoenixHomeInspector.com www.inspectorpages.com/lgreen |
...for safety. ____________________________________________ "An Education, not just an Inspection" Larry Kage Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond. ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Newer GFI's will not reset if wired improperly or if the protection circuitry has been lost.
| bathroom fan trips GFCI | Sal Rappa | Electrical | 3 | 12/27/08 2:30 PM |
| More GFCI info from U/L | Greg Fretwell | Electrical | 9 | 12/4/07 9:33 PM |
| GFCI Safety Notice | rcooke | Electrical | 1 | 10/30/07 1:29 PM |
| GFCI receptacle trips... | lkage | Electrical | 4 | 6/20/07 9:39 AM |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical | 0 | 7/7/06 1:24 PM |
