| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
Should the outlet under the kitchen sink be a GFCI? From what I understand all outlets within 6' of water should be GFCI protected.
| Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America) |
It is not required by code as the outlet does not serve the counter top.
"Never underestimate the difficulty of changing false beliefs by facts." |
What about the outlets in the laundry room do they need to be GFCI?
If they supply the washer, they do not need to be GFCI'ed. |
No, but could someone fire the Carpenter that butchered that cabinet around that outlet.
Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
If they did that, then 85% of the Carpenters wouldn't be working. This is a typical mess for a kitchen cabinet. |
Remember now......if the washer receptacle is within 6' of the edge of the sink. It would indeed require the receptacle to be GFCI protected. Nothing in the NEC would allow the washer receptacle IF in that 6' area to not be GFCI protected.
Paul W. Abernathy,CMI,CEI,CEPE NECŪ Consultant/Columnist www.twitter.com/ElectricalGuru - ICC & IAEI Certified Electrical Inspector - ICC & IAEI Certified Electrical Plans Examiner - Look for my article in the Nov/Dec 2009 IAEI Magazine - 2007 "Top Gun" Winner - Mike Holt Enterprises " visit www.TheElectricalGuru.com Today !" |
Even a dedicated cicuit? ____________________________________________ "An Education, not just an Inspection" Larry Kage Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond. ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Good point... |
Paul, can you elaborate on what that means? Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
He's stating that if the washer is plugged into an outlet and this outlet is within 6 feet of a sink, it should be GFCI'ed
I don't really make a big deal out of this situation. |
Most dishwashers I see share the same receptacle under the counter cabinet with the pig, that is what is confusing, it is within 6' of the sink.
Ya, but a homeowner would more likely plug into an outlet behind a washer (at a convenient stomach height) verses an outlet located in a lower cabinet where they have to crawl into to get access to the concealed outlet.
| Composite granite kitchen sink ... good choice? | Bill Featherstone | Plumbing | 6 | 1/9/08 12:03 AM |
| More GFCI info from U/L | Greg Fretwell | Electrical | 9 | 12/4/07 9:33 PM |
| Outlet under kitchen sink | adooley | Electrical | 3 | 2/13/07 3:50 PM |
| venting the kitchen sink | kblair1 | Plumbing | 57 | 12/8/06 4:37 PM |
| No GFCI in Kitchen | rnewland | Electrical | 6 | 9/19/06 8:51 AM |
