Old 12/10/09, 6:37 PM
mnahrgang's Avatar
Default GFCI vs. GFI
Was asked today, What is the difference between GFI and GFCI? I gave an answer, that it was the same thing. But after thinking about it, I don't know that for a fact. I've just seen them used interchangeably for so long that I assume they are one in the same.
Are they two physically different things, or are they the same?
Mark Nahrgang
www.HeyMark.info
Find an InterNACHI certified District Of Columbia Home Inspector (and anywhere else in North America)
Old 12/10/09, 7:24 PM
Default Re: GFCI vs. GFI
Most people use it interchangeably.....the main difference is them putting the "C" (circuit) in there... which can be vague at times. Putting a GFI on a receptacle does protect the person from electrocution at that receptacle.....but it may not protect it down the line depending on how it is wired or the system itself.... which is why it is vague.... but that is being technical.
Jeff
Old 12/10/09, 7:29 PM
They are the same thing.
The gfi may be older lingo for receptacle usage.
Larry Kage, CMI
231 929 3525
Old 12/11/09, 7:30 AM
jnieblas's Avatar
jnieblas jnieblas is offline
Please Note: jnieblas is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thumbs up Re: GFCI vs. GFI
I agree they are the same thing...
Old 12/11/09, 8:55 AM
mrichardson1 mrichardson1 is offline
Newbie question.............what's the best tester one would recommend?
Old 12/11/09, 8:57 AM
Joshua L. Frederick Joshua L. Frederick is offline
http://activerain.com/blogsview/1362...tween-gfci-gfi
Old 12/11/09, 9:08 AM
James H. Bushart's Avatar
The only test recognized by the NEC is operating the buttons on the device, itself. If they trip the circuit, but your tester doesn't, it is not (officially) the receptacle or breaker that is defective.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 12/11/09, 9:23 AM
Chuck Evans's Avatar
I use the button on the device when I'm at the device itself and use the three light tester to check downstream outlets.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 12/11/09, 9:54 AM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
My tester will not test a GFCI if there is an open ground wire, which is not actually required to operate the GFCI. I would agree, and have myself come across several GFCI's that operated with the buttons and not the tester.
Old 12/13/09, 2:42 PM
It is better to understand that the real thing to be thinking about that GFCI or GFI come in Class A or B types. The mA levels of activation (protection) vary from 4-6mA and up for Class A and 20 mA to 30ma ( depending on the manuacturer ) for Class B types. It is important to remember that the Class A will save a life while the Class B will not.....Class B are for equipment protection only.
Many engineers call the GFCI the Class A and the GFI the Class B....but I believe it is just more important to know which Class than the actual verbiage of the device's name.
Paul W. Abernathy
Old 12/13/09, 2:50 PM
Also another tidbit....when we look at some larger electrical equipment that has built in GFI prtection...it is not really circuit protection as you would see in the term GFCI...it is not really any circuit protection at all in these types of setups...so it would truly be only GFI protection and not GFCI protection.
So while we can use the jargon as we feel fit.....and I do it all the time for convience. It is also nice to know that in real world their are differences in the two terms.
Paul W. Abernathy
Old 12/13/09, 3:17 PM
mnahrgang's Avatar
Is it correct (in laymens terms) to think of GFI protecting only the receptacle, where GFCI also protects the down stream receptacles as well?
Mark Nahrgang
www.HeyMark.info
Old 12/13/09, 3:37 PM
Ahhh....well if you are asking my opinion then I don't believe it really translates into that. I believe the correct verbiage should be GFCI for the protection aspect of the 4-6mA and above protection and use GFI for the 20mA and up protection for equipment and then use GFP for the requirement for 230.95 150V to ground and not exceeding 600V type of protection on service equipment where applicable.
I would not have a problem with someone calling a GFCI a GFI as well....call me me but depending on the application, someone knowing what you are talking about will know which you are talking about so I kinda don't worry about the symantics of it but some will disagree ( but I dont let those people bother me...I beat to my own drum )
With that said I don't think your view of it is too off base...in fact the more I say it your way the more I like it...... The act however of a single GFCI device not protecting any devices down stream would still make it a GFCI Device in the eyes of the NEC regardless.
Ground-Fault Circuit Interrupter (GFCI).
A device intended
for the protection of personnel that functions to deenergize
a circuit or portion thereof within an established
period of time when a current to ground exceeds the values
established for a Class A device.
Paul W. Abernathy
Michael Larson's Avatar
I think Paul is saying that GFI protection while protecting equiment is not equivalent to GFCI protection.
GFCI is people protection.
GFI is equipment protection and trips and a much higher level than a GFCI.
Michael Larson
Hudson, WI
Old 12/13/09, 3:39 PM
yeah...Im kinda saying that but I found it is easier to waddle through the muck if you just learn to call them GFCI Class A Devices when you want to deal with the devices that protect human life....
Paul W. Abernathy
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 12:29 PM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 9:31 AM
