I was going to look into this on my own and not here but thought why not ask the pro's so others could learn also if needed.
What is the difference between a GFCI and a surge protector? I had a Elec friend tell me that a GFCI is not the same as a surge protector and i agree but do they do the same thing? Paul, i expect you to give me a GREAT answer! Thanks a lot! Andy B |
I'll try. A GFCI protects from ground faults (such as an electrical short), whereas a surge protector protects against surges (such as a lightning strike or a power outage). You can buy a surge protector with built-in GFCI protection. In fact, all of my surge protectors have built-in GFCI and a test and reset button.
A GFCI looks for a current imbalance in the hot and neutral wires. The assumption is that any current supplied by the hot wire that does not return through the neutral wire is finding its way to ground via your body. I don't know exactly what the current trip threshold is, but it is in the neighborhood of 15-30 milliamps. And it trips very quickly.
A surge protector protects against excessive voltage resulting from a lightning strike or similar event. I am less familiar with them, so I will let someone else chim in here. |
Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
As has been mentioned, GFCI protection is for personnel protection. The devices are set to open at between 4 and 6 miliamps. That would be considered an "A" type of device. There are also "B" type devices that are set to open between 20 and 40 miliamps. The "B" types have a larger range as the manufacturer will have different settings based on the type of usage. The "B" type is more for Equipment protection, not personnel protection, such as Snow melting and Deicing type equipment.
Surge protective devices, and TVSS (transient voltage surge suppression) are much different than GFCI protection. This has become a very complex part of the industry and more information can be found by Googling the topic. There are two different Articles in the NEC for the two different types of protection (1.Surge protection, 2. TVSS protection). Art 280 Surge Arresters, and Art 285 TVSS. Generally speaking, there are 2 main differences between Surge Arresters and TVSS. 1. Location of installation of the two.(Surge Arresters-Line side of service disconnecting means, TVSS-load side of service disconnecting means) 2. Type of protection they offer,. Each offers different types of protection (Generally: Surge Arresters-Lightning, high voltage, TVSS-transients). |
Useful post, Pierre. Thanks.
I hope you join NACHI before you get to 100 posts. NACHI 2005 U.S. Member of the Year
Thanks Russel.
I do not think I can join NACHI. I am an electrical inspector and Instructor. I do think that this organization is trying to improve the HI industry, that is why I post here. It also helps me keep aware of how your industry interacts with the electrical industry in general. |
Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
And I see this topic is already covered so I will move on.....Great Stuff! Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Busy......sorry.....working on a new power point presentation for a whole new series of electrical classes...and working on my DVD editing of a full electrical inspection walk around.
Awesome stuff guys!
Here are a few electrical questions as i am waiting for West Michigan to have an electrical seminar to ask my 100 questions. If you come across a home with the old 2 wire system and no ground, how do you call out recommendations if they ask? Like if the Fridge or Living room for TV or computer room, well any high watt appliance plugged into wall. Do you tell them to add GFCI or do you say surge protector or both or do you just what? I just googled the GFCI and Surge combo and that is pretty sweet. I have seen the ones with multlple plugs but not the single plug but maybe i haven't looked hard enough. Appreciate the guidance! Andy B |
If I give my advice and they have another electrician come in then they can say well Roy said this is what we should do . "Ungrounded outlets recommend upgrade by qualified person." Usually when this is found there are many more concerns in the home and the complete system needs to be upgraded. Example too small a service usually over fused many two prong receptacles. . In this case I "recommend complete electrical upgrade throughout by qualified person " Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Also, If I ever saw a fridge or freezer pluged into a GFCI I would recommend that it NOT be plugged into a GFCI. If it trips out all the food is gone to waste.
I like Roy and George, or at least the recommendations in the above two posts.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| Inspection Pointers Here | jtedesco1 | Electrical Inspections | 3 | 3/15/08 10:19 AM |
| GFCI Safety Notice | rcooke | Electrical Inspections | 1 | 10/30/07 1:29 PM |
| The question asked on the new HI Study test here? | jtedesco1 | Electrical Inspections | 28 | 10/4/06 10:31 AM |
| UL Information about Testing of GFCIs | jtedesco1 | Electrical Inspections | 0 | 2/5/06 5:38 PM |
