Old 12/4/11, 11:11 AM
Bruce L. Treacy Bruce L. Treacy is offline
Question GFI
Do GFI's have an operational life span? Being somewhat mechanical maybe they wear out.
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/4/11, 11:18 AM
Robert Meier's Avatar
Default Re: GFI
If I had to guess I would say that the cheap electrical components would fail first.
Old 12/4/11, 12:17 PM
Jeffrey R. Pope's Avatar
Default Re: GFI
Based on the fact that the manufacturers recommend "monthly testing," my answer would be YES, although I've never seen a recommendation that they be replaced every X# of years.
I would bet that if you were to contact Leviton, they would provide you with a more accurate answer.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/4/11, 12:39 PM
Default Re: GFI
I have had one in my bathroom now for over 15 years and has not failed yet.
On the other hand, GFCI's in the construction field, only last about 6-12 months. Mainly due to exposure to the elements and tripping occurrences.
Old 12/4/11, 12:42 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Default Re: GFI
Go with Leviton I have not found one yet that has failed in HI testing.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/4/11, 1:03 PM
Gary D. Rowden Gary D. Rowden is online now
Default Re: GFI
There are two types of GFCIs that can be installed, “GFCI circuit breakers” and “GFCI receptacles”. While many people prefer to use GFCI receptacles inside the house and circuit breaker types for the outside power. The two main disadvantages of GFCI circuit breakers over receptacles can be cost and inconvenience (resetting), but GFCI circuit breakers will typically outlast GFCI receptacle.
And while one of the common complaints concerning a GFCI receptacle is their short life span. Even though some can last a very long time, others just a few years, and some can fail shortly after installation. Typically using a higher grade GFCI receptacle will give a longer life span; look for specification grade, commercial grade, and hospital grade. These are much higher quality units for just a few dollars more.
Old 12/4/11, 1:19 PM
Default Re: GFI
http://www.electricalmarketplace.com...mation-W1.aspx
Old 12/4/11, 1:25 PM
Default Re: GFI
Nice reference. I find it funny that the author would use the words 120 volts and 220 volts in the same article.
Old 12/4/11, 1:32 PM
Default Re: GFI
Probably because he was addressing a Work Shop Setting, like I have in my basement or others in their garage.
Only reason I see Robert.
Old 12/4/11, 1:35 PM
Default Re: GFI
I was just pointing out that you cannot have 120 and 220 volts in the same system. A technical article should make an effort to get that right.
Old 12/4/11, 1:38 PM
Default Re: GFI
I see your point, it could be misleading to some viewers, but I thought nothing of it at that moment.
Old 12/4/11, 1:44 PM
KEVIN WOOD's Avatar
Default Re: GFI
Leviton has a pocket guide on there web site If you don't have it, get it. More new types of Outlets coming on the market and you have to keep up with the times. www.leviton.com
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/9/11, 7:22 PM
Scott May's Avatar
Scott May Scott May is offline
Send a message via Skype™ to smay
Default Re: GFI
Now they have outlets with USB ports...who would have thunk!
Try not to become a man of success but rather to become a man of value!
WWW.eyespy-homeinspections.ca
Serving: Collingwood, Creemore, Dundalk, Durham, Flesherton, Hanover, Kincardine, Mansfield, Markdale, Meaford, Owen Sound, Port Elgin, Sauble Beach, Shelburne, Southampton, Stayner, Thornbury, Wasaga Beach and Wiarton.
Old 12/9/11, 10:14 PM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is offline
Default Re: GFI
Scott -
Do you subscribe to "Structure Tech" on Facebook? I saw that too....tried to find if they were listed...
Chad Norlen
SEI Inspections
Certified Professional Inspector
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
Old 12/9/11, 10:51 PM
Bruce A. King's Avatar
Default Re: GFI
GFI's from the 80's are mostly all bad or have been replaced already.
The later models seem to be more reliable so far.
The latest versions do a self check when you trip and reset so you will start seeing more failures during the inspection.
Once this gets to be a "pattern" it will be time to recommend the electrician test them while he is there repairing the other issues found if the house is occupied with the owners relying on these to operate for daily use.
Would you want to watch one fail on the day before a holiday when the owners have company coming on a tract home with all bathrooms on the same GFCI?
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
