In an older home with a two wire non grounded system.
Can a GFI be installed without being grounded to water system or some other means of grounding the outlet? I am unclear as the NEC make two specific notations about this type of system. Thanks for the input. |
| Find an InterNACHI certified Wisconsin Home Inspector (and anywhere else in North America) |
See: http://www.mikeholt.com/mojonewsarch...1~20020102.htm InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Yes, but you must become the grounding conductor!
Care to give it a try?! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
No issue.
Two-wire systems are grounded, are safe, and are still code compliant. GFI's will work.
However, it will not work with your standard 3 light tester (due to the way the tester works). Use the test button on the GFCI device itself to test. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
If I am not mistaken, the only method that is authorized by the NEC to test the GFI is with the button on the device, anyway.
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
An ungrounded GFCI should be labeled as such. There is typically a label in the original packaging to use.
But how many devices have you found that test internally but fail to test externally or are wired wrong downstream and don't test?
While I am not totally certain, I'm reasonably sure that the NEC recognizes the fact that some indications of "pass" or "fail" could be from faulty test equipment as well as faulty GFI's. Accordingly, it officially allows and recognizes the test button on the receptacle, itself, as the test that counts. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
My point is your point...
Does "as the test that counts" mean that it is the only acceptable test procedure that they recognize? If so, I have dozens of cases where the device tested OK, but was not. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
It is my understanding that a GFCI can be wired to do exactly that. It will protect whatever is downstream, without disabling the power at the receptacle itself. If it should be disabling the power, then I write it up as "mis-wired". |
I added the original comment to clarify for folks so they didn't write ungrounded GFCI devices as defective because they did not trip with their three light tester. I do, however, use my three light tester to test the downstream protected outlets on grounded systems. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
| Question for all... | Bob Hopton-Jones | General Inspection Discussion | 9 | 4/6/07 7:43 AM |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/20/07 11:56 PM |
