Old 2/9/10, 9:28 AM
Bobby Hamilton's Avatar
Bobby Hamilton Bobby Hamilton is offline
Default Give the ground wire a tug
On yesterdays inspection, the ground wire to the buried rod wasn't visible (snow and earth covered). Gave it a tug and came right out of the ground.
Bobby Hamilton
Bloodhound Home Inspection Services
Youngstown Home Inspection
Austintown Ohio Home Inspection
Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/9/10, 10:06 AM
Marcel Gratton's Avatar
Default Re: Give the ground wire a tug
Attachment 34825
So you broke it!
On The Level Inspection
Gatineau, Québec
Old 2/9/10, 10:29 AM
Originally Posted by mgratton View Post
So you broke it!
You can't break what isn't properly attached.
Bobby Hamilton
Old 2/9/10, 7:35 PM
Be careful, you can light yourself up that way.
Old 2/9/10, 8:08 PM
Brian E. Kelly's Avatar
What the frick is that black thing on your hand or the white stuff on the ground???
Old 2/10/10, 10:23 AM
Well, when your dealing with 8 degree weather and 15" snow, you'll understand.
Bobby Hamilton
Old 2/12/10, 6:39 PM
Rick Marton Rick Marton is offline
Report it that an electrician should attach it back to the ground rod with an acorn. Pain in a butt to do in the winter trying to dig up frozen ground to find the rod but it has to be done . The rods grounding conductor wire is only a supplement to the ground wire going to the water meter. Hopefully that one was connected. Rick
Old 2/12/10, 7:31 PM
Nope, they connected it to the plumbing about 10' from the box, when the meter is about another 30' away.
Bobby Hamilton
Old 2/12/10, 7:34 PM
That can be done only when the house is fed by well water and not by city water. If its fed by city water than the wire should of went to the water meter. Rick
Old 2/12/10, 8:46 PM
Jim Port Jim Port is offline
Unmoderated Guest
Attachment 34909
Depending on the age of the house that was quite common. More recent codes have required the connection to be within 5' of the water line entrance on a metallic piping system.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 2 1/8/11 8:04 PM
Cut Service Ground Wire. htennyson Electrical Inspections 6 4/6/09 8:54 AM
Looking for comments on this service ground wire connection cbuell Electrical Inspections 6 2/8/07 7:27 PM
