Old 8/3/11, 11:07 PM
Mike D. Freeman Mike D. Freeman is offline
Default Goo in receptacles?
Performed a inspection today and found odd looking substance in probably 90% of the receptacles. It was always in the bottom grounding hole of the three prong receptacle. It was dark brown and appeared to have be fluid enough to run down the receptacle a short distance. My first thought was some type of insect but I don't know why they would only enter the grounding port. Has anyone see or heard of this? See attached photos. Thanks for any information.
http://
http://www.nachi.org/forum/attachmen...1&d=1312427168
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/4/11, 12:01 AM
Robert Ernst Robert Ernst is offline
Default Re: Goo in receptacles?
This has been discussed on here before. I would bet the house has an ungrounded two wire system. This is know to be done to make sure someone doesn't plug something in that requires a ground. I personally don't like it and would recommend that the two prong receptacles be installed.
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 8/4/11, 1:00 AM
The material in the hole was soft and would not stop a plug. I did use a knife and pull some out to see if I could tell what it was. The house was 24 years old so I don't think two prong wiring would have been installed. It was a foreclosure and had probably sat a while. Not sure if this had anything to do with it or not.
Old 8/4/11, 2:40 PM
Barry Adair's Avatar
bugs many types as long as the can get their arses in to lay eggs
wasps filled these
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 8/4/11, 8:29 PM
Yep 24 years wouldn't require them to be filled in. Weird stuff. The bugs and their eggs is gross but I guess anything is possible.
www.homecsi.com
Exterior GFCI receptacles lfreeze Electrical Inspections 11 1/14/07 6:30 PM
open ground on 3 garage receptacles dnasser Electrical Inspections 14 10/30/06 5:53 PM
Receptacles Mounted on Covers jtedesco1 Electrical Inspections 1 2/5/06 12:13 PM
Answer to a common question about GFCI's jtedesco1 Electrical Inspections 4 1/12/06 9:29 PM
