During an inspection today I was down in the basement bathroom, went to plug my tester in the outlet and it blew clean out of my hand and into the sink. Didn't even trip the breaker (FPE Panel). Charred the ends of the tester.
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Good reminder to keep your distance when plugging in!
Glad you're OK Bobby. Any pics of the FPE Panel?
Thanks Chris. Here's one, should've guessed there would be dbl taps all over the place by just looking at the telephone wire connections to the left of the panel.
FPE-- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
What was wrong with the receptacle to cause the tester problem? |
You are a lucky guy Bobby. If the panel is FPE or Zinsco I do not pull them, waaaaay too dangerous.
Yeah, the FPE panel is a hazard, but that was not the cause of the incident. Any idea what it was? It seems wierd, by the picture, the ground pin has a char mark on it.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
If that had happened to me on an inspection, I'd be quickly calling for an electrician to check out the house wiring.
. Imagine if this happened when plugging in some type of appliance? |
And your reference to the client would be based on what? Just so I am clear. The issues with Zinsco was more so over the aluminum buss that came into effect at the onset of a copper shortage in the late 60's...otherwise please explain your concerns..and not just want you read on some websites. As for FPE....other than a CRAPPY wiring job...their is space in that panel and so on....looks very clean. So while you would defer it and possible the client could have the breakers replaced with proper UL listed aftermarket breakers like "challenger"....whats the reason you would recomment full replacement....? We read WAY to many things on the internet that lead us to make statements that mislead people. Yes, FPE was part of a class action suit in New Jersey and yes they did lie about their UL listings...but remember they are still used in canada under federal pioneer without the same issues....but still have the stab design. The CPSC did a test and did not recommend a full recall...so yes, defer them simply because the breakers dont function...but you might suggest to them if they do nothing to atleast look into replacing the breakers with aftermarket UL listed ones that do meet UL standards..... Just a thought.....versus blanket statements..... Paul W. Abernathy |
| GutterStuff on the Today show - Link to segment | tmcnamara | Ancillary Inspection Services & Additional Topics | 0 | 10/9/08 6:48 AM |
| GutterStuff on the Today show - Link to segment | tmcnamara | Exterior Inspections | 0 | 10/9/08 6:47 AM |
| GutterStuff on the Today show - Link to segment attached | tmcnamara | Miscellaneous Discussion for Inspectors | 0 | 10/9/08 6:41 AM |
