Should the bulbs be changed while the tub is empty or full?
That's actually a pretty spectacular code violation. You can't have any sort of "hung" fixture over a tub of any sort.
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I hope the windows are tempered glass so they don't get cut too bad when they fall through them after getting shocked.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Trust me, it was definitely called out in the inspection report.
I don't think I have ever seen that one before, but have seen wall sconces associated with tubs.
Wait
Those are low voltage lights If I were the seller that would be my story Remember we are not the code guy Great pix may I use it? rlb |
Low 120 volts! You may copy the image.
Thanks John
rlb |
Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Emergency Lighting (commercial) | mcyr | Electrical Inspections | 24 | 6/10/06 10:06 AM |
| NACHI Great Lakes - East Chapter | rcooke | Canadian Inspectors | 5 | 5/31/06 7:27 PM |
