Old 3/23/10, 7:37 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Default Green bonding screw
Doesn't the green bonding screw need to be attached to the panel. The bar is broken on this Cutler Hammer 125 amp 1/0 aluminum main panel.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/23/10, 7:55 PM
Robert Meier's Avatar
Default Re: Green bonding screw
Sometimes those little bonding bars are shipped with their green screw tapped into the panel but not landed on the neutral bar. It appears that the screw has a small piece of copper that should have been entered into one of the holes in the neutral bar and tightened.
Old 3/23/10, 8:19 PM
Christopher Currins's Avatar
Is this a sub panel? I see no grounds.
In a sub panel the neutral bar is NOT connected to the panel.
Christopher Currins
Certified, Licensed
Old 3/23/10, 8:28 PM
I only see a three wire feed and it looks like it is coming from a meter base.
Larry Kage, CMI
231 929 3525
Old 3/23/10, 8:40 PM
Jeffrey R. Pope's Avatar
I see a bonding strap/jumper that is not attached. Where's the broken "bar" you're referring to?
The three-wire feed is fine for service equipment, but I too wonder where all the egc's are. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/23/10, 9:07 PM
The broken strap not attached is the bar I'm referring to. The bar that the bonding screw is attached to it which is left of the neutral bus. I know my terminology is off so please set me straight.
The egc's are crammed down at the bottom left behind all the bundling.
This was a main panel as I mentioned in the first post.
Old 3/23/10, 10:09 PM
Jeffrey Moore Jeffrey Moore is online now
I cannot see where the egc's are attached anywhere. Are they just bundled together or are they attached somehow/somewhere?
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
Old 3/23/10, 11:13 PM
Then you are correct, the bonding strap (the copper strap/jumper with the green screw) should be attached directly to the neutral terminal bar.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/25/10, 5:53 PM
Great. Thanks for your help.
Any further wording that you would add. Here is what I put in the report. The photo is the same photo I posted.
The green bonding screw is not attached to the neutral bus bar via the copper pipe behind the dead front cover. PHOTOGRAPH "L"
Old 3/25/10, 8:15 PM
It's possible (not likely, but possible) that the bond was established elsewhere.
The neutral conductors are required to be bonded to the enclosure at the service panel. A bonding connection was not visible and should be verified or established by a qualified electrician.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/25/10, 8:42 PM
Jeff,
Since this panel contains the service disconnect and has an offset nipple connecting it directly to the meter enclosure where else do you think that bond could be?
Old 3/25/10, 9:15 PM
I've seen instances where bonding conductor was attached to the neutral terminal and to the grounding terminal - just a wire run between each terminal bar.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Siemens distribution panel bonding screw installation jfrederick Electrical Inspections 10 8/18/09 9:42 PM
Bonding Screw kmalone Electrical Inspections 25 4/6/08 6:16 PM
Neutral bus bar failed inspection Greg Moritz Electrical Inspections 18 1/19/08 1:53 PM
Subpanel Bonding Screw away Electrical Inspections 24 1/9/08 2:46 PM
